Results 1 to 12 of 12
    Apr 2011
    Default Opel Astra H Fault U2117 - No illumination on Display CD30 and Climatic
    Hi. I have problem with 2005 Astra H. Display and Climatic not working, but Radio Working. No illuminations in central console.
    Fault: U2117 Can Bus No Communication With DIS ... and also B2652-01/02
    I've checked all fuses, they're all okey.
    Nothing is modified in the car. Car at the parking, everything ok, next day to start the car and noticed the problem.
    Apr 2011
    Anyone please ?
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    You have PM for solution.
  4. The Following User Says Thank You to simaservis1108 For This Useful Post:
    Tawe (10th February, 2016)
    Apr 2011
    Problem solved If anyone is interested, PM me.
    UK East
    Why solution secret? Was it just a battery disconnect in this case?
    Sep 2013
    garage
    probable flash need some heat
    Apr 2011
    In other cases,probably will need some heat,in my case,there was some black dirt on mcu,after very good cleaning problem is solved
    Apr 2019
    Default Opel Astra H 2004 - Display and Clima is dead
    Quote Originally Posted by simaservis1108 View Post
    I seem to have tha same problem. The display and the clima is dead. Radio works but no lights show in the central unit. There is no PID error when i check the error codes. Also i cheked all the fuses and its fine.
    Can you tell me what to check?
  10. #9
    Aug 2018
    East Pole
    Can be a bad earth.
  11. #10
    Apr 2019
    hello
    i changed the display and it worked. i kept the old one to check for any obvious damage.
    The anoying thing is that the "new" one needs programming because it works on safe mode!
    But at least i have clima!
  12. #11
    Mar 2016
    Hi, I have a problem with my Astra H GID display. It`s Siemens VDO KP
    The display is working but there is a problem witch contrast. Some part must be
    broken but I just don`t know where to look.
    If anyone saw such a defect and could suggest something, I woluld be grateful. 20191205_174846.jpg
  13. #12
    May 2018
    Displayy PCB cold soldering problem, just not sure where exactly. I just dissembled display removed first PCB and gave good hot air blow all over it on both sides with some flux here and there. Good luck all. Fixeddd !!!!!100%
