In eeprom - 95160
Hello friends
Here a Megan 1.9dci, as the title!
Without programming injectors codes,
in diagnostic tool, code all AAAAAA all injectors!!
Tested with Clip, and other diagnoses "programming error"
Where are the codes in Flash or EPROM?!
ThK
..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
Eprom.
Write virgin eep and use clip to reprograming.
centrohifi (11th February, 2016)
I assume you read write flash over obd so is possible to repair over obd
Write these file
info on pm
regards kire
IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
bobolin4o (11th February, 2016), centrohifi (11th February, 2016), ecutuners (11th February, 2016)
Thanks @Kire106ka .... 20sec ... car perfect
hi there
sorry for dragging up an old post
was wondering if someone could help me i am having a similar issue i have a 2004 1.9 dci megane and i had a guy out to flash the ecu with tune now upong doing this my codes have now changed to 6 A ie: AAAAAA
The car starts and idles fine but revs are limited to 1500 RPM as tho the car is in limp home mode as i believe this is due to the injectors having no / incorrect codes.
would it be possible for someone to help me and give me some clues how to go about recoding my injectors to my car ? i will be buying a clip this week if i know how to reprog them
thanks in advance
Chris.
You have a look on the injectors must be some letters and no thats your injector codes
Sent from my SM-G925F using Tapatalk
Hello everybody! There was a similar situation after the failure of OBD on reading. As I understand the problem is treated by replacing VIRGIN EEP DUMP. Esle anyone can help, I will be very grateful. Thank you!
