First u need to put ori file and reset dpf.
Second put my file.
Please report.
Hello
Car Mercedes W211 E280 CDI EDC16 - DPF off need
Can anybody help?
I send file to one company but not work. I attachment both files to compare
1037392670 - E280 W211 3.0CDI - ORG.zip
1037392670 - E280 W211 3.0CDI - ORG - DPF OFF.zip
Second put my file.
Please report.
TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
If I helped you please use button Thanks.
DoctorCar (11th February, 2016)
I hope you have recover your money from such "real" company !
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
hmm.. it's not simply, they charge money but recover...... They said "File is OK, you have problem in car"
CustomCars (11th February, 2016)
They said "File is OK", but really not good.
All full worked manual solutions - FAP/DPF OFF, Adblue/SCR OFF, EGR OFF, TVA OFF, SWIRL OFF, O2/Lambda OFF, DTC OFF and etc
Our database available for download 24/7 on EVC server for all legal WinOLS users
My friend rides 2 months and all is well.
Thanks to Mariusica_Boy
I share to fast. Car don't smoke and don't add oil, but today check light go on and fault codes:
P2626 - DPF to much saturation
P2084 - DPf something problem with flow
and with measur parameters saturation is 255%
When I make replacement DPF fault is gone, but I think in next month problem come back
Power is OK then I think only need turn off fault codes
wiski (6th June, 2016)
Maybe wrong but I think this SW version has to be done BDM as it depends on maps not readable by OBD.
you shouldn't be getting this codes if dpf off is ok, also 255% is not good..
