Hi mates, i start this thread to share kess and ktag cables and adapters pinouts.
Maybe together we can get all the pinout cables motorcycles, tractors, boats, DSG and Adapters ktag.
i will star with this, DSG DQ200 and DSG DQ250
DQ200
DQ250
BMW Bike Cable (thanks to pinotec)
That's right but home made don't be have quality like thats.
So for look and quality, must pay to be more pro
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
it may be that you're right, but I do not think there difference in quality in a single cable
busaman (12th February, 2016)
I made a dq250 - obd female cable with switch on/off power. Not beautiful to see, but it's functionally.
if you need expensives tools to work, you arent pro, your tools are pro
being PRO in actual time should able giving you possibility buy good stuff and don't lose really priceless time haha
Sure, all here understand what we talking about. Sure hand made is good, like i say only looks worst, and some time needed more time to setup.
narkeleptk (20th September, 2017)
thanks to pinotec for bmw moto pinout
pinotec (24th March, 2016)
Hi, for some you might find this useful. i needed to flash my dq250 with kessv2 and didnt have a cable so i decided to make one. it worked perfectly and still does so i decided to share the diagram i made. i got the connector from my local junk yard.
if you find this helpful drop me a thank you.
clickerfux (7th June, 2018), datapage (8th September, 2018), HIC (20th October, 2018), krammer2262000 (16th February, 2019), lupus80 (4th October, 2020), marcin249292 (15th May, 2023), moky (13th February, 2017)
can one has the kess v2 original cable pinout.? i need to make 2adaptors from obd cable to Man TGS obd diagnose plug to R/W the ecu and the same thing to a volvo fh12 ... can any one of you help me?
hello and please help verify my Kabbalah is it correct because my kess v2 5.017 is not communicating with cars
obd2 ---- bd25
1 ---- na
2 ---- 22
3 ---- na
4 ----24
5 ----25
6 ---- 18
7 ---- 8 i 10
8 ---- na
9 ---- na
10 ----21
11 ----na
12 ---- na
13 ---- 17
14 ---- 5
15 ---- 23
16 ----12
needle 11
Hi i try find pinout 144300T 104 , i try connect jtag mpc55xx .
Regards Michal.
no links to members sites in sigs
