Results 1 to 4 of 4
    dominik.m's Avatar
    Jun 2009
    POLAND
    Default 0261207179 036906032P ME7.5.10 NEED HELP
    HI ALL.
    VW GOLF IV 1.4 (AXP) 0261207179 036906032 29F400
    It is possible to to switch off egr in this ecu?
    If so I ask about help this.
    SALUTE
    mariusica_boy's Avatar
    Quote Originally Posted by dominik.m View Post
    HI ALL.
    SALUTE
    You need to remove the fault code really. Then manually block the EGR with a plate. Whats the exact code which is coming up from the ecu?
    TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
    If I helped you please use button Thanks.
    dominik.m's Avatar
    Jun 2009
    POLAND
    16791- P0407
    17812- P1404
    Somebody can help remove dtc?
    dominik.m's Avatar
    Jun 2009
    POLAND
    Problem still not solved.
    Somebody can help?
