Results 1 to 7 of 7
    Feb 2015
    Default VW Passat 3C 2.0TDI PPD 16V 170hp Motor:BMR - NEED DPF off AGR off please
    Hello
    can someone help me to make DPF off and EGR off in the Software?
    Car is a: VW Passat 3C 2.0TDI PPD 16V 170hp Motor:BMR
    READ with MPPS
    Many thanks in advance
    mariusica_boy's Avatar
    Your file dpf off+egr off
    First u need reste ash from dpf.
    Second put my file.
    Pass in PM.
    TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
    If I helped you please use button Thanks.
  3. The Following 3 Users Say Thank You to mariusica_boy For This Useful Post:
    imotion (13th February, 2016), tlc76 (6th April, 2017), tommyno18 (31st August, 2019)
    Jan 2012
    Bucharest, Romania
    Hi Mariusica,
    I have exactly the same engine. Moreover, the dump file is 100% identical with the one posted by imotion.
    Can you please send me a PM with the archive password?
    many thanks,
    Cristian
    Sep 2015
    Hungary
    Quote Originally Posted by tlc76 View Post
    Hi Mariusica,
    many thanks,
    Cristian
    Use this....
    03G906018EM_EGR+DPF OFF.ZIP
  6. The Following User Says Thank You to Stig33 For This Useful Post:
    tlc76 (9th April, 2017)
    Jan 2012
    Bucharest, Romania
    Thank you @Stig33.
    What is the "physical" procedure for removing the DPF? Any particular action?
    What operations should be carried out before writing the "03G906018EM_EGR+DPF OFF.ZIP" dump (e.g. set ash value to zero) ?
  8. #6
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    l always set to new dpf fitted before writing , but it might not make any difference
  9. The Following User Says Thank You to smirnoff_rules For This Useful Post:
    tlc76 (11th April, 2017)
  10. #7
    Sep 2016
    Hello can i get the pass. Thx mate
