where did you hear this its utter nonsense
I have seen KV A780 working fully. When I played with the box I noticed it had a totally new firmware called "Infinity x n001 PV4.3.0.8". The main menu also had a different background.
The person who has this firmware is talking about money....surprise surprise.
Maybe someone can help locate above firmware cos I know A780 is working.
After a bit of digging around turns out A780 still working but only if connected **********. This box has now gone in line with all the other boxes. *******************
I'd say better off trading in the box and purchasing something new with HD
as always post the proof in showing it working on the 780 closed sourced box.
I bet he works for sv like you say kid closed source box mischief making me thinks
Yeah but be careful what one purchases I bought this so called Zgemma Star H1 DVB
Which turned out to be a Clone off of Fleebay for ?67
The Linux software within it is Crap, The EPG within it is Crap, the so called Plug-In's
Is Crap, the Software does not perform as it's advertised & suppose too so that is
Crap as well, & it's a major process operation to become familiar with it's Menu
& also there are untold amount of Cloned Boxes being flooded on the market from
China yeah to basically fund their drugs & gambling habits yeah if I was you all
then I would give this box a wide berth, thanks but no thanks they are basically
a total waste of money/time & space sincerely & that's a fact yeah laters folks.
@BJTT what do you expect for ?67, it's just one step up from an openbox series. It takes research and patience to setup any E2 Linux box from scratch, hence why for the Zgemma plug and play brigade there's loads of pre made backup images available and even then sat forums are still littered with newbie problems.
To anybody else don't be put off, the Zgemma is a great upgrade option for any one owning a openbox on a tight budget. If you follow the guides and info on this forum alone you'll have it working correctly within an hour and you won't reget spending the money.
Yeah Martin 035
So for example where do I find ATV 5.1 Upgrade on the Site as mentioned by other Posters
Because I certainly do not see it under the Downloads Tab under Zgemma Star H1/H2/S2
Etc-etc?
Also, where does one find The Sky HD Skin 3.008 as mentioned on the Website because
my EPG @ present is Naff
As someone who has done his research on DK you should know that the Slyk 1 HD skin is a manually download skin and not an EPG plugin it is also not available via the download plugins section, search DK you will find it. To get your EPG working correctly install either crossepg or xmlimporter from the download plugins. Configure the plugin and you will have a better EPG
Yeah Martin 035
So exactly where is Cross-peg or xmilmporter in the Downloads Tab/Section?
Could you be a bit more Specific please?
this is not a Zgemma Star H1/H2/S2 post perhaps take it somewhere else?
martin035 (14th February, 2016)
If you read the post it's not hearing it's what I witnessed with my own eyes taffydav!
If I was working for sv don't you think I wouldn't have recommended we all jump ship to sv? At no point have I made reference to sv..
It would be better if we work together rather then slating each other and being so negative!
I am sharing info. What you do with that info is up to you
and all i ask is a working screenshot of box said working.
