You can buy ready kit for emulate, but that's crap.
Read it by good tool and change in SW, best way - no high consumption issue.
Only orginal tools like X17, Ktag (check list), CMD
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
dalisman (16th February, 2016)
If engine is 2.2d and have the 5th injector, you can take off plug from it and put resistor, then will have no more smoke(regens) but will not turn check engine light off. If engine is 2.0d will need to do it in sw or by emulator.
Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
POPS & BANGS (Schubabschaltung, Crackles) on allmost every petrol
send file I will disable it.
I use x1u and work fine with it .
If you have someone ho can read send it will make it.
Other way is emulator.
P.s ktag still not supported all denso have lot of no id.
Chiptuning/DPP/EGR/LAMBDA(O2)/FLAPS/Adblue/DTC OFF / EDC17 Immo OFF
Kess v2 eu. clone full/Ktag eu. Clone 6.070 full
Info on pm
Kess v2 ori , K-tag ori, MAGPro2 x17, Galleto v54 EU ,Winols ,AVDI full ori, Orange 5 /Omega /Xprog/Upa all ori , VAS Pc , Porsche PIWIS 2 and etc........
