I am also interested, I've been looking for a damos for a while
Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
POPS & BANGS (Schubabschaltung, Crackles) on allmost every petrol
send file it can be done
totalkey (17th February, 2016)
i did some reading and find that i need to remove the hole system and put new pipe.
my question is if i can only change parameters that the car will not goes into limp mode and not delete the system?
With correct SCR OFF solutions you need to disconnect SCR control unit ( if it separate ) and NOX sensor without touched/disabled limp mode and all DTC tables ( DTC disabled selectivity ).
All full worked manual solutions - FAP/DPF OFF, Adblue/SCR OFF, EGR OFF, TVA OFF, SWIRL OFF, O2/Lambda OFF, DTC OFF and etc
Our database available for download 24/7 on EVC server for all legal WinOLS users
can you explain a little bit more? what exactly i need to do?
can you do it? i can pay for a good solution
You need to disconnect the SCR unit and NOX and read all stored errors, better is for full SCR OFF.
i read with ktag, edc17cp18 part 12649719 aa7x
silvardo.zip
Nobody did this before maybe?
You have stored DTC ?
