Results 1 to 15 of 23
    dave11674's Avatar
    Florida, UK
    Default W204 ESL fault...can they be fixed ?
    Hi guys
    recently i had a W204 set sent to me
    2 x gen 3 keys
    1 x ESL
    1 x EZS
    so i connected it up and found the NEC needed taking off and renew
    i did this OK
    so put nec back on and tested switches
    (im following the PDF here)
    all ok
    so i rebuilt as instructed and write factory again but this time the ESL did not goto the lock position !!
    no noise from the ESL at all, no clicks, no motor trying to turn etc etc
    speaking with ST on skype i was advised a few things but to no avail
    so im thinking the ESL is broken in some way from the customers side !!
    has anyone had this problem and fixed it ?
    i put the new simon touch motor in too
    if you have fixed the ESL and want to share how you did this then it would be greatly appreciated.
    dave
    EDIT
    i have good comms with the nec over k line i get all the info out of the unit
    so i believe K line is working ok and the ESL to a certain extent
    its just when i try write virgin image after rebuilding the motor does not turn and the ESL does not lock
    i get error locking in my simon touch tools
    im thinking may be a voltage reg or may be a relay is broke inside the ESL
    my soldering is 200% been soldering a long time
    my power supply i bought especially when i bought the ST tools
    regulated 12v 10Amps so i know this is spot on
    it worked perfectly on a few previous jobs
    i have 2 x ESL here with similar probs
    the other does try to spin the motor but cant seem to turn it !
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Smok PSA, volvo & ford
    If someone helps you DONT FORGET TO SAY THANKS its only polite....
    pepi's Avatar
    You can test the switches with PCB taken off from the board. Also take care when you unsolder NEC be ware you can take off smal smd elements near the NEC .
    Sent from my SM-G925F using Tapatalk
  3. The Following User Says Thank You to pepi For This Useful Post:
    dave11674 (19th February, 2016)
    dave11674's Avatar
    Florida, UK
    Thanks pepi
    my soldering is 200% so no moved or missing components
    switches are fine i tested before reassembly
    i got a locked and unlocked reading also moving when holding no switches
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    puiu's Avatar
    Timisoara
    Try to change relay,if the old engine had worn brushes, could destroy the relay contacts
    Puiu
  6. The Following 2 Users Say Thank You to puiu For This Useful Post:
    dave11674 (19th February, 2016), mercis (19th February, 2016)
    dave11674's Avatar
    Florida, UK
    Hmmm
    i did think the relays
    do you know a replacement part number ?
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
  8. #6
    autodigitec's Avatar
    Aug 2011
    PT
    Did you check if problem is not the NEC and tried it in a fully working ESL? Out of the many NECs I renewed and adapted, I have one that is somehow damaged, has good communication, read switches fine, but only activates the relays IF battery is higher than ~12.1V.
    Working on something to release next month for free for all dk users :>
  9. The Following User Says Thank You to autodigitec For This Useful Post:
    dave11674 (20th February, 2016)
  10. #7
    dave11674's Avatar
    Florida, UK
    im wondering if i should of gotten a 14v 10A PSU now
    tho it has done other ESL fine
    does anyone know where we can get compatible relays from ?
    PS i dont have a working ESL to test
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
  11. #8
    Birmingham
    Dave,
    So did the Esl have blocked status (AA)
    And you've got NEC keys with it?
  12. #9
    dave11674's Avatar
    Florida, UK
    yes mate the nec was fluffed
    i followed the PDF
    it took 14hours to rectify the NEC
    but got there in the end
    now when i check switches it says esl repairable just change motor
    but i think the relays are fluffed
    as when i try to write the factory image to the esl when its built back up it does the TP ok and but locking at the end it errors out on me, i get no sounds or clicks from the esl
    new motor in also bought from ST
    not a sausage
    hopefully it is the relays not switching, as no clicking noises from teh esl
    fingers xssed eh
    or do you have some input here mark ? its greatly appreciated
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
  13. #10
    smayer's Avatar
    Jan 2012
    Do you read key pasword and generate new file to ESL?
    I have had a bad experience with Fly ....
  14. #11
    dave11674's Avatar
    Florida, UK
    not yet
    i need to get the ESL to lock when i write factory dump to it first before i write any dumps in
    ive ordered some of the relays
    going to see if that fixes it
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
  15. #12
    smayer's Avatar
    Jan 2012
    I see some defective NEC after renew with ST (very bad) tool
  16. #13
    dave11674's Avatar
    Florida, UK
    can we put a new NEC in then ?
    if so where can we buy these NEC blanks from ?
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
  17. #14
    Quote Originally Posted by dave11674 View Post
    dave
    Try The Legend
  18. #15
    workshop
    legend esl doctor-useless
