Give car vin code(last 8 numbers) and I give to you correct wiring diagram.
VF38E9HR8
CL005399
Thank you tarts1999
Alternator 5VNR---5pin black connector
IC57A 10VNR -----10 pin black connector
engine ecu 53VNR--53 pin black connector
ali kaptan (3rd April, 2020), auto12volts (28th September, 2021), jmac200t (23rd May, 2021), kev90 (29th December, 2023), mikajna (23rd August, 2018), radiodecoder23 (11th March, 2017), robert1966 (7th September, 2020), rytismulti (24th February, 2016), sharediag (1st November, 2018), Wolfson (23rd November, 2018), zokster (17th August, 2019)
I found info about you error code. Check, maybe it help.
ali kaptan (3rd April, 2020), jmac200t (23rd May, 2021), radiodecoder23 (11th March, 2017), rajnai (21st November, 2022), robert1966 (7th September, 2020), zokster (17th August, 2019)
HI i need pin of peugeot 607 by vin,Help me someone if you can,damp is damaged cant read,
Hi I think problem solved , was alternator LIN bus short, after disconnect 2 wires near alternator car again driving no problems with gearbox, still no charging
I am newbee here. I can not download this rar file.
I am newbee here. I do have the same problem with U1400. How I can download your pictures.rar file?
U 1400 error code peugeot 208 did somebody solve it?
Do you know the LIN-bus speed?
