Results 1 to 15 of 22
    Aug 2010
    Default lambda cat mercedes ml63amg
    hi can you help me to remove lambda cat from ecu ml 63 bosch me9.7
    thank you
    Feb 2013
    Got flash?
    Aug 2010
    what do you mean
    Aug 2010
    no one can help me
    post extracted files
    Aug 2010
    ok thank you very
    You have generic dtcs?
    Pxxxx?
    Feb 2013
    File attached. I asked you for the flash.
    Aug 2010
    hi it dosen t work iwant to erase g3/5 G3/3 G3/4 G3/6
    sond O2 KAT P0161 P0141 P0160 P0140
    THANK YOU
    Dec 2013
    Use DAS to disable
    DPF/FAP off, AdBlue off, EGR off, Throttle valve off, Flaps off, DTCs off, Lambda off,
    Feb 2013
    Quote Originally Posted by camecas View Post
    THANK YOU
    It works perfectly fine. None of those are catalyst codes. They are heater and circuit codes.
    Aug 2010
    no dosnt work for this car the problem still the same
  13. #13
    Aug 2010
    i need help for this can som one help me
  14. #14
    try and report
  15. #15
    Aug 2010
    hi
    luca .kart youre files is good butt still one sond i?n memory g3/3 can you help me to desactivated
    thank you
