Results 1 to 3 of 3
Thread: 7N0959243A
    Nov 2009
    Default 7N0959243A
    this dump help with ECU defective fault stored and door will stop working
    it can be use for left and right side door, there are same ECU's
    first you have to read and save your original coding, perhaps you have to change it
    you have to power down both sides or battery, it will initialize for left or right side mounting when powered up
    I've done it by desoldering 95160 from PCB and works perfect
    Aug 2015
    I need a dump with this post. maybe he has someone
    Nov 2009
    Quote Originally Posted by marekm View Post
    sure I have, mine is still working with this dump!
    where is your's dump to ensure it's same HW and SW?
    if I helped you please press "Thanks"-button at my posting,
