Results 1 to 15 of 22
    matekhr's Avatar
    Croatia
    Default Clio 2 Campus new key
    I need to program a new key with remote for Clio 2008 Campus, 1 button key.
    I have an used PCB and a factory new PCF7946.
    Can anyone explain how to precode PCF chip to make a remote work.
    But please, step by step, for dummies... I never dealt with car keys before.
    Thanks in advance.
    coolsoda's Avatar
    Apr 2008
    Scotland
    All this information is in the Forum
    You can buy a new Chinese key for less than ?10 on ebay,this would be your best option.
    http://www.ebay.co.uk/itm/Remote-Con...cAAOSwDuJW1TFU
    scotland clydebank
    you need truecode to extract the 12 digits pincode if you have not got truecode or zedfull you will not extract the 12digits pincode needed for programming key easy if you have the right tools just phone a local locksmith cheaper .
    szkeptmen's Avatar
    Hungary
    Quote Originally Posted by godfathertre View Post
    Good joke...
    He is the local locksmith...
    Polak, wegier dwa bratanki i do szabli i do szklanki
  5. The Following 2 Users Say Thank You to szkeptmen For This Useful Post:
    Atex31 (1st March, 2016), instakeys (6th March, 2016)
    autochei's Avatar
    Mar 2013
    romania
    he is a locksmith and he don t know how to precode 7946 dor renault remote .? he it s a begginer
    p1et's Avatar
    Oct 2013
    Guys, easy:
    Quote Originally Posted by matekhr View Post
    Anyway, for precoding this chip you need proper transponder programmer but better to buy new key for the low price as coolsoda said...
    lion0304's Avatar
    Oct 2014
    Thanks in advance.
    Here you go for config PCF7946 Renault 1 button.
    But buy some already precode is the best way (no lose time and money)
    Use Hitag programmer, precode ID46 Renault PCF7946.
    After that check config pg6 PCF like picture and clic write
  9. The Following 2 Users Say Thank You to lion0304 For This Useful Post:
    armpower (27th April, 2016), nenadgorgi (21st November, 2019)
  10. #8
    scotland clydebank
    without the pincode how is he going to program the key and also for the price of key not worth loosing time the biggest problem is pulling the pin code.
  11. #9
    mikajna's Avatar
    Mar 2015
    For this car to pull out pin code, he can use Carprog (as most cheaper option), chinese FNR 4in1, or even Renault Can Clip + Renault Pin extractor...but as member @coolsoda says, for that car you already have all info here on forum, but you need to little explore with search button
  12. #10
    Jan 2011
    REUNION ISLAND
    Hello
    Renault Precoded transponder won't work on this clio.
    U need to read dump of uch 93c66, then prepare chip with zed bull and programm via obd with oin code found.
    Easy option is to programm a remote which does not need precoding
    Envoy? de mon GT-I9515 en utilisant Tapatalk
  13. The Following User Says Thank You to WISETIGER For This Useful Post:
    p1et (2nd March, 2016)
  14. #11
    matekhr's Avatar
    Croatia
    Thanks for all the answers.
    I see I should clarify my question from the first post.
    First of all, I'm not local locksmith, but according to frequent requests, I should become one.
    Original key with remote control is lost, and the owner asked me to make a new one. I extracted the PIN frum the UCH, and succedded to program a new key, but remote control is not working.
    I found on the forum that in order to make a remote control to work, PCF chip must be precoded in a proper way. So, precoding procedure is my problem. (as I wrote before, I have no experience with car keys).
    Regarding Renaults, I have Renault Clip, DDT2000 (very usefull tool), Carprog and access to chinese zed bull/effi interface.
    Are these tools enough for make remote control operational? And how?
    (yes, I know I need a new PCF7946)
  15. #12
    Oct 2015
    all what you need in pm
    best regards
  16. #13
    Jul 2013
    Scotland. UK
    You still not sussed out how to read an 8 leg chip yet?
  17. #14
    Dec 2018
    hello, it will posible send me tutorial, i have same problem. Thanks
  18. #15
    Dec 2016
    poor forum , give us real informations for doing this £40 job !
    Clio 2 campus = Encrypted ISK = no ddt2000 no can clip & NO MORE FNR 4IN 1 can do the job !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Just buy 30€ RenOlink FREEWARE and program 10€ expressesALI PCF7946 key .https://fr.aliexpress.com/item/Renol...27426c37u44Ndt
    https://fr.aliexpress.com/store/prod...2def7d87WS99D2
