All this information is in the Forum
You can buy a new Chinese key for less than ?10 on ebay,this would be your best option.
http://www.ebay.co.uk/itm/Remote-Con...cAAOSwDuJW1TFU
I need to program a new key with remote for Clio 2008 Campus, 1 button key.
I have an used PCB and a factory new PCF7946.
Can anyone explain how to precode PCF chip to make a remote work.
But please, step by step, for dummies... I never dealt with car keys before.
Thanks in advance.
you need truecode to extract the 12 digits pincode if you have not got truecode or zedfull you will not extract the 12digits pincode needed for programming key easy if you have the right tools just phone a local locksmith cheaper .
he is a locksmith and he don t know how to precode 7946 dor renault remote .? he it s a begginer
Here you go for config PCF7946 Renault 1 button.
But buy some already precode is the best way (no lose time and money)
Use Hitag programmer, precode ID46 Renault PCF7946.
After that check config pg6 PCF like picture and clic write
armpower (27th April, 2016), nenadgorgi (21st November, 2019)
without the pincode how is he going to program the key and also for the price of key not worth loosing time the biggest problem is pulling the pin code.
For this car to pull out pin code, he can use Carprog (as most cheaper option), chinese FNR 4in1, or even Renault Can Clip + Renault Pin extractor...but as member @coolsoda says, for that car you already have all info here on forum, but you need to little explore with search button
Hello
Renault Precoded transponder won't work on this clio.
U need to read dump of uch 93c66, then prepare chip with zed bull and programm via obd with oin code found.
Easy option is to programm a remote which does not need precoding
Envoy? de mon GT-I9515 en utilisant Tapatalk
p1et (2nd March, 2016)
Thanks for all the answers.
I see I should clarify my question from the first post.
First of all, I'm not local locksmith, but according to frequent requests, I should become one.
Original key with remote control is lost, and the owner asked me to make a new one. I extracted the PIN frum the UCH, and succedded to program a new key, but remote control is not working.
I found on the forum that in order to make a remote control to work, PCF chip must be precoded in a proper way. So, precoding procedure is my problem. (as I wrote before, I have no experience with car keys).
Regarding Renaults, I have Renault Clip, DDT2000 (very usefull tool), Carprog and access to chinese zed bull/effi interface.
Are these tools enough for make remote control operational? And how?
(yes, I know I need a new PCF7946)
all what you need in pm
best regards
poor forum , give us real informations for doing this £40 job !
Clio 2 campus = Encrypted ISK = no ddt2000 no can clip & NO MORE FNR 4IN 1 can do the job !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Just buy 30€ RenOlink FREEWARE and program 10€ expressesALI PCF7946 key .https://fr.aliexpress.com/item/Renol...27426c37u44Ndt
https://fr.aliexpress.com/store/prod...2def7d87WS99D2
