Hi friends,
can someone tell me where I can order remote key for Citroen Jumper 2009?? It doesnt have to be original... It can be also fully functional key from china.... Price is important for customer.
Thank you very much
Hi friends,
Thank you very much
from china no exist but u can find sh
3DGroup have the aftermarket ones
apollo auto have cheap genuine key $42
https://www.apollo-auto.com/products...-and-brand-new
joolsik (18th April, 2016)
That's for a Citro?n Relay.
The Citro?n Jumper is a Citro?n Dispatch.
Citroen Relay is Jumper
Dispatch is Jumpy
Atex31 (3rd March, 2016)
Are they both based on the Renault Kangaroo?
The Jumper is fiat based with a ford transit (puma) engine.
I know,
It was a Kangoo joke!![]()
So... Adapting key with AVDI was no problem, but I am not able to adapt remote control... Key should be ok...
If I want to connect do BCM to learn remote control with AVDI: I write the pin, it is accepted, but after a while I get answer: negative response. Any hint on this?
IF KEY ADAPTED THE REMOTE SHOULD WORK CITROEN and PEUGEOT TOO MANY DIFFERENT TYPES OF REMOTE KEYS and also if cheap chinese keys half of the times do not work only the immobiliser part of key works better cloning key and adding a cheap
remote locking kit or buy good quality remote.
I know... I already have some chinese crap where remote control doesnt work at all...
I just want to know right procedure how to adapt remote for Citroen Jumper with PCF7946
1) First adapt immo and then remote control? or
2) Adapt just immo and then remote control will work too?? Its normal for PCF7946....
Another thing is that AVDI dont even let me to adapt remote control.... When I try to start the procedure of learning... it writes negative error immediately...
Remote is programmed when precoded from bcm dump then add key with pin by obd..
There is no remote programming procedure , thats if its a PCF7946
Thanks Kev
joolsik (19th April, 2016)
If you precode 7946(not 7936 , because their precoding procedure is different than each other) , probably key is wrong
There are 2 type key, magnetti marelli or delphi- you have to use magnetti marelli key. Maybe you used delphi ? so it is not compatible with this car.
SM-G920F cihazımdan Tapatalk kullanılarak g?nderildi
No, just need add some data from dump of bsi, rsk low, hi and rcfg
