Results 1 to 14 of 14
    dimitar's Avatar
    Default Qashqai SID305 dpf egr off
    can someone please help with this one please
    obd read with galletto
    is it safe to write via obd with galletto
    need dump and advice
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    DK Veteran elmassioui's Avatar
    Dec 2010
    Default dpf off
    hi
    this is dpf off
    pass pm
  3. The Following User Says Thank You to elmassioui For This Useful Post:
    dimitar (6th March, 2016)
    dimitar's Avatar
    Doesnt work, after 1000km dpf problem p2002
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    soundnavigator's Avatar
    Sep 2010
    If the ash counter not stopped ... normally.
    All full worked manual solutions - FAP/DPF OFF, Adblue/SCR OFF, EGR OFF, TVA OFF, SWIRL OFF, O2/Lambda OFF, DTC OFF and etc
    Our database available for download 24/7 on EVC server for all legal WinOLS users
    dimitar's Avatar
    bump bump bump
    still need help
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    It's not to hard ecu. But sure soot level should be resett, i maked it a lot and no problem, but no one fill to max.
    Sure needed make reset, then testing.
    All brand FileService - Custom - remapping company
    POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
    | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
  8. The Following User Says Thank You to CustomCars For This Useful Post:
    DashProg (15th March, 2016)
  9. #7
    dimitar's Avatar
    i bave resseted soot quantity to 0% before i wrote file
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  10. #8
    rabie_m's Avatar
    Jun 2009
    morocco/sale
    PST PASS I CAN SWITSH OFF DTC
  11. #9
    dimitar's Avatar
    but car is in limp mode
    dtc delete wont solve the problem
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  12. #10
    dimitar's Avatar
    still need help with cruise controll
    does anyone have working solution for cruise controll?
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  13. #11
    dimitar's Avatar
    bump bum0 bump
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  14. #12
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    Write to us, we will help you solve problem - free.
    To complicated talk by forum.
  15. The Following User Says Thank You to CustomCars For This Useful Post:
    pike (24th April, 2016)
  16. #13
    kinketotua's Avatar
    Apr 2016
    Europe
    try these
    I tested in a car and runs fine
    --> QASHQAI_dpf_chck.rar
  17. The Following 2 Users Say Thank You to kinketotua For This Useful Post:
    dimitar (24th April, 2016), pike (24th April, 2016)
  18. #14
    dimitar's Avatar
    I still need help to make this piece of crap working
    Everthing ok only cruise controll not work
    Is there a possible solution or should i put dpf back
    Thanks all for your efforts
    50w Soldering Iron
    Chisel
    Sometimes Hammer
