Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 66
  1. #46
    Aug 2013
    uk
    Quote Originally Posted by spiridonas View Post
    I reinstal without internet and now working fine.
    Please how can work with internet ?
    Need to enable firewall about xprog port ?
    i couldnt get it to work with internet on aswell... allways seems to kill the software then have to re unpack everytime ...but if anyone figures it out let us know.
    Glad the software working good for you now.
    If i helped.... please dont forget to press the THANKS + REP buttons .
  2. The Following User Says Thank You to thayer201 For This Useful Post:
    ramzibakri (29th October, 2017)
  3. #47
    aem's Avatar
    Jun 2014
    snowboarding on the mountain
    i can confirm.install without internet and work without internet there is no verify error never.working perfect
  4. #48
    Nov 2012
    5.5.5 runs fine releasesd on mmh originally. Your not setting you fuse bytes right??? and it only likes to run on xp (virtual machine helps).
  5. #49
    Apr 2013
    United Kingdom
    Hi, ive already got an x-prog 5.55 with dongle. Can I run this software without flash atmega chip? Thanks
    Hit like and thanks if I've helped you!!
  6. #50
    Jun 2016
    Default Xprog m 5.6 clone
    Does anyone know if i can downgrade my xprog m 5.6 clone to 5.5.1? and use it without a dongle? Any information would be greatful
    Quote Originally Posted by urcarpc View Post
  7. #51
    jakesman's Avatar
    Oct 2013
    Bethlehem Southafrica
    m8 if u can get the files for atmega and eeprom , u can flash it to that version so up or down do not matter aslong as u have the files and software that goes with it u should be fine , i went from 5.3 with dongle to 5.5.1 and up to 5.5.5 and down to 5.5.1 and again up to 5.5.5
    Ask a dumb question and become wise for the rest of your life, but act wise and stay dumb
  8. The Following User Says Thank You to jakesman For This Useful Post:
    mikeg332 (13th February, 2017)
  9. #52
    Jun 2016
    Thanks bud for your prompt response. It is much appreciated
  10. #53
    Oct 2014
    Netherlands
    Hi guys, do you know if there are files available for v5.60 ?
    I currently have v5.55 without dongle.
    Rgs H2Deetoo
  11. #54
    Oct 2017
    Por favor, pida ayuda con mi xprog 5.6 error: silenciosamente dispocitivo.
    Si puedo ser detallado lo que hay que hacer ya que soy nuevo en esto. ¡¡Muchas gracias!!.
  12. #55
    Mar 2017
    Quote Originally Posted by Rodi81 View Post
    Try different usb cable and make sure the COM port in xprog software Oprions > Environment is the one you see xprog is using in windows device manager when you plug it in, if you don't see it in device manager then you have a drivers problem, try reinstalling them. Also write in english, no todos hablan español aca.
  13. #56
    Oct 2017
    Hello and tested don different usb cables and still giving the same error and tested in xp (32bist), win7 (32bist), win7 (64bits) and does not work.
    It is xprog 5.6 with dongle.
    I can flash it to some other vercion. I have the programmer upa to be able to flash.
    In the case of flash to which vercion they recommend me.
    I will be very grateful for your help !!
  14. #57
    Mar 2017
    Your error seems to be the software has no communication with the device. Did you make sure the COM port set in xprog software is the same assigned to the device when you plug it in? If nothing else works, yea I'd say try reflashing it, sorry I can't recommend a specific version, mine works well out of the box without reflashing so far.
  15. #58
    Oct 2017
    Hi Wokcz if the communication, ports and drivers are correct.
    My question is whether flash can be done to any vercion and if the software has to be with dongle obligatorily or is indifferent (I consult this since my computer is with dongle).
    Another question is how to charge the authorizations, or are loaded automatically with the flash and / or software.
    I am very grateful for your help.
  16. #59
    Oct 2017
    Another question I have is that I must do first. If you upload the eeprom file and flash or modify Lock bits and Fuse Bits.
    I check this out because when loading eeprom and then modifying lock bits the content of eeprom is modified.
    I do not think it's a software problem because three of our colleagues have the same problem with xprog 5.6 with dongle
  17. #60
    Mar 2017
    If you flash it, you wont need to use the dongle anymore I think. Sorry I can't comment much on the flashing procedure, I never did it so far, I have 5.4 with dongle and haven't tried upgrading it yet.
