Results 1 to 15 of 17
    Spain
    Default PROBLEM READ WITH GALLETO 4 EDC16U1
    Hi.
    I'm trying to read a ecu BOSCH EDC16U1 with galletto 4 (clone), and is not possible. reading start and when it reaches 36% stops. (view photo)
    Can you help me.
    Thank you
    (sorry for my english)
    Jun 2012
    I think it's a problem of your tool. You are not the first with this problem on this tool at 36%.
    Connection on ecu is good? You apply good 12v to adapter?
  3. The Following User Says Thank You to cawadany For This Useful Post:
    ernesto1670 (7th March, 2016)
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Friend is a CLONE !! does not always work!
    see power 12,8V or disassemble and read BDM
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
  5. The Following User Says Thank You to centrohifi For This Useful Post:
  6. #4
    Spain
    Quote Originally Posted by cawadany View Post
    If the connection for BDM is good, and 12V, they are correct.
    Jun 2012
    Quote Originally Posted by centrohifi View Post
    It's in BDM yet
  8. The Following User Says Thank You to cawadany For This Useful Post:
  9. #6
    Jun 2012
    Quote Originally Posted by ernesto1670 View Post
    Can you try with another tool?
  10. The Following User Says Thank You to cawadany For This Useful Post:
  11. #7
    Spain
    It's in BDM yet
    Yes in BDM
    I have no other tool.
  12. #8
    Jun 2012
    Yes in BDM
    Where are you from?
  13. The Following User Says Thank You to cawadany For This Useful Post:
  14. #9
    Spain
    Where are you from?
    I am from Spain
  15. #10
    Jun 2012
    Sorry, you are not near to me....
  16. The Following User Says Thank You to cawadany For This Useful Post:
  17. #11
    Babos's Avatar
    Mar 2012
    why you need read via BDM?
    that ecus can good remap via OBD!
  18. The Following User Says Thank You to Babos For This Useful Post:
  19. #12
    Spain
    Quote Originally Posted by Babos View Post
    It is not possible for OBDII, I need full read, to clone
    GOLF V TDI 140
    0281011843
    I'll have to buy BDM100. Everyone speaks well of this team.
  20. #13
    Jun 2012
    Yes, to clone you have to make bdm. Made one same ECU clone 2 weeks ago.
  21. The Following User Says Thank You to cawadany For This Useful Post:
  22. #14
    EUROPE
    GOLF V TDI 140
    0281011843
    If i can understand you want to replace this ecu with another?
    If you found same ecu number then you can read the 95320 eeprom and copy paste to the second ecu.
  23. The Following User Says Thank You to kospoz For This Useful Post:
  24. #15
    Spain
    Quote Originally Posted by kospoz View Post
    It is not the same reference, you need to clone full.
