Results 1 to 12 of 12
    Holtek's Avatar
    Default Renesas SH7055 - reading and programming via Piasini
    I have a PCB with Renesas SH7055 processor. This is not ECU from car. On the board are placed holes programming to which I connected Piasini according to the figure:
    Then I read Flash with success . The problem came when I wanted to write FLASH. According to the documentation Piasini should do two bridges. Connect the pins 16, 2, 19, but where? To which I have to connect the processor pins 16, 2, 19, and where to do bridges?
    Guess you need to measure that out on an ecu for comparison.
    Looking at the datasheet it is related to FWE pin andd MDx pins for setting the right mode.
    Programming/Erasing Execution To program or erase, the FWE pin must be brought high and user program mode must be
    entered.
    eprst's Avatar
    Jul 2011
    Russia
    Hello, i have the same situation. Volvo S60 AT with HD64F7055F40 (the same as SH7055). The problem is that i can read it but don't know how to write it. All the pins (FWE, MDx) are in positive position - 1. I found the datasheet where is written that there is "user program mode" if all pins are positive (see attachments). As i have only one chance i want to be sure how to write it. So, what pins should i bridge to write this chip properly?
    Thanks in advance,
    All the best
    Holtek's Avatar
    This file helped me solve the problem
  5. The Following 3 Users Say Thank You to Holtek For This Useful Post:
    ALBERTO_ (5th August, 2021), Darek90 (21st January, 2017), eprst (20th January, 2017)
    eprst's Avatar
    Jul 2011
    Russia
    I don't have pins Pxxx on my PCB. Could you explain how it helps? Where should i connect GRND? "toggle P407 at 125Hz at TTL levels (to keep WDT happy)" - how did you use it?
    Thanks in advance,
    Holtek's Avatar
    Reading and writing SH7055 by Renesas Flash Development Toolkit:
    RST - pin 58 - to VCC via 1k and during start short to ground for a while
    MD0 - pin 59 - to VCC
    FWE - pin 56 - to VCC
    MD1 - pin 55 - to GND
    MD2 - pin 50 - to VCC
    CS3 - pin 44 - to VCC
    SCK2 - pin 164 - clock 125Hz from generator
    TX1D - pin 165 - to TXD FTDI
    RX1D - pin 166 - to RXD FTDI
    10MHz quartz
    Best regards from Poland
  8. The Following 5 Users Say Thank You to Holtek For This Useful Post:
    diagtula (4th October, 2019), DSAuto (8th May, 2020), eprst (23rd January, 2017), makeu4u (9th April, 2017), teamtuner (21st January, 2017)
  9. #7
    Aug 2016
    Quote Originally Posted by Holtek View Post
    10MHz quartz
    Hi brother !
    I tried but I could not found P405 to P413 point in mainboard . Here is the picture of my mainboard . Hopefully you can help me read and write this ECU
    https://1drv.ms/i/s!AoLE0w8hGfMnoH79z7mOiUoHJblA
    https://1drv.ms/i/s!AoLE0w8hGfMnoH8v8CZ6D_xv_whX
    Thanks you
  10. #8
    Aug 2016
    You mean we can read and write the chip directly from the pins right?
    p405 (pink) is VCC
    p407 (purple) is the 150 hz 555 timer signal
    p409 (orange) is TX
    p411 (yellow) is RX
    p413 (black) is ground.. this also goes to one side of the capacitor as shown.
    So now we connect diect to the pins as you say
    10MHz quartz
    can you make sure
    p405 is what PIns number?
    1 more question . can you make usb same PDF file and sell for me . if ok please inbox me for your price. thanks brother
  11. #9
    Holtek's Avatar
    I do not know your ECU from Subaru. I had a problem with the programming of the processor, which was installed in another device. All signals connected it directly to the pads processor. It worked. Therefore, shared his knowledge, he himself had learned. P405 - VCC - Locate on the board capacitor C416, around the processor that filters the supply voltage. On it will be + is VCC and GND is -.
  12. The Following User Says Thank You to Holtek For This Useful Post:
    vietdiesel (21st January, 2017)
  13. #10
    Apr 2015
    pin 1 and pin 20 ? can be changed ?
  14. #11
    roth18's Avatar
    US
    Quote Originally Posted by sanyagans View Post
    pin 20 is GND and pin 1 Vcc, he made a mistake
    Best Regards, Roth.
  15. #12
    Oct 2018
    egypt
    so no way to do it with piasini and must be with renesas flash development toolkit ? ... on an ecu included with piasini manuals performed with success and measured to know pin id's but with another not included i cann't
    wbr.
