Results 1 to 9 of 9
    Tagne's Avatar
    Aug 2014
    BATA EQUATORIAL GUINEA
    Default ECU VW GOLF SWAP IMMO PROBLEM
    hello and happy women days for women in this forum
    please i would need help i have this original ecu that is spoilt ; i bought used one from yart
    i swapped eeprom 950.... i fit on car i still have security on board ; please i need somebody to tell me what i have
    to swap on ecu to start the car.... thx you in advanced IMG_20160308_182527_650.jpg
    Dec 2009
    More info about the car would he handy to work out what Immo you have.
  3. The Following User Says Thank You to gurmk For This Useful Post:
    Tagne (8th March, 2016)
    Nov 2009
    no swap eeprom
    adapt with vcds using pin
    Tagne's Avatar
    Aug 2014
    Quote Originally Posted by koyot View Post
    no swap eeprom
    THX YOU HOW TO GET PIN CODE . I DON T HAV VCDS.....
  6. #5
    dijo's Avatar
    Apr 2010
    You need to post eeprom dump... to get pin...
    which kind of troubles you have with ori ECU?
    match Ori ECU and second one his part nr.
  7. #6
    Tagne's Avatar
    Aug 2014
    Quote Originally Posted by dijo View Post
    thx you to respond
    ori ecu when i connect it check engine is off and the security light is off too
    when iconnect used ecu check engine is on and security light is on too
    will put two dump for pin code later
  8. #7
    Faraday's Avatar
    May 2012
    The dark side of the moon
    What is the year of car?
  9. #8
    Tagne's Avatar
    Aug 2014
    9508 ORI.rar9508 USED.rar
    please i need pin code for both ecu thx you
  10. #9
    Nov 2012
    HUSI- ROMANIA
    pin code 00728
  11. The Following User Says Thank You to vorovei constantin For This Useful Post:
    Tagne (15th March, 2016)
