Results 1 to 8 of 8
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Default pin key dash Polo 2008 9S12H256
    please, do not find code Key !!
    Polo 2008 Dash Marelli 9S12H256
    Please
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
    dyzio's Avatar
    Jan 2014
    Racek
    .03409.............
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    try ... thk ......
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    with what, I can program key ??
    He tried with many diagnoses, but have no function !!
    I tried with VCDS, I find no solution!
    Tried with VAG Tacho 5.0, recognizes function, but asks me 4 codes, I've 5 !!
    FVDI .. program this model ??
    Jun 2013
    And you made as:
    TP23 or ID48?
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by centrohifi View Post
    So try without 0 at the beginning (3409).
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    yes .. try 3409 not working!! Tomorrow try FVDI
    p1et's Avatar
    Oct 2013
    Pin is 100% correct so maybe you have some lockout time... Try Ign. ON for 30 min/1 hour(?). This is no fancy car, you need standard 48 chip. VCDS should program key without problem.
