can somone point mr in the direction of the Openbox S12 clone safe firmware pls.
Are the s9 s10 s11 s12 all same? do they work on each other?
new to openbox prefer dreamboxes.
From searching the web it looks like Feb 2012 was the last release of any firmware for the s12 whether a clone or not, therefore there's a good chance your already running the latest firmware.
the firmware i installed crashed the box (clone bomb).
martin035 (14th March, 2016)
I downloaded the firmware by Anonymous, it doesnt have any sat list also for some reason it doesnt let me upload tp list either. It say tp list corrupt. But if I use s**box firmware I can upload the same tp list without issues, only problem clone bomb.....
is there clone safe with sat list set up?
got stable firmware but cant view channels for some reason, due to forum rules it cannot be discussed either.
yea, all apart from channel 5. everythinf seems to work apart from **cam, which shows online.
its all ok on my dm500
tried both, dhcp on/off 2 different routers. scr***led
It does show my thing is online with a tick next to it.
nope did not try DNS, I'll give it a go later.
It's working
I didnt have to change anything, all I did was used the dm500 looped the output to the S12. Still not getting few channels like ch5, I've made a no signal fix using a diode but still not getting some channels. The major ones most seem to be working![]()
Been playing baout wiv it and it only works when i connect it through the dm500. Otherwise none of the channels work. I tried the sat feed direct, the same one i use for dm500 and it didnt work, even using the diode fix. This box is b****cks. Dm's are the best. This has truly got me confused.
Any thoughts people. All help is much appreciated
Thank you
