Results 1 to 15 of 15
    DK Veteran mini's Avatar
    Apr 2008
    W Yorkshire
    Default Openbox S12 Clone safe
    can somone point mr in the direction of the Openbox S12 clone safe firmware pls.
    Apr 2008
    W Yorkshire
    Are the s9 s10 s11 s12 all same? do they work on each other?
    new to openbox prefer dreamboxes.
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    From searching the web it looks like Feb 2012 was the last release of any firmware for the s12 whether a clone or not, therefore there's a good chance your already running the latest firmware.
    Apr 2008
    W Yorkshire
    the firmware i installed crashed the box (clone bomb).
  5. The Following User Says Thank You to mini For This Useful Post:
    martin035 (14th March, 2016)
  6. #5
    Apr 2008
    W Yorkshire
    I downloaded the firmware by Anonymous, it doesnt have any sat list also for some reason it doesnt let me upload tp list either. It say tp list corrupt. But if I use s**box firmware I can upload the same tp list without issues, only problem clone bomb.....
    is there clone safe with sat list set up?
  7. #6
    Apr 2008
    W Yorkshire
    got stable firmware but cant view channels for some reason, due to forum rules it cannot be discussed either.
  8. #7
    P&D's Avatar
    May 2010
    Are you getting the FTA channels ?
  9. #8
    Apr 2008
    W Yorkshire
    yea, all apart from channel 5. everythinf seems to work apart from **cam, which shows online.
    its all ok on my dm500
  10. #9
    P&D's Avatar
    May 2010
    What are you getting on screen No signal or scrambled ?
    Go into the setting make sure DHCP is on & reboot the box.....see if that sorts the problem
  11. #10
    May 2012
    Quote Originally Posted by P&D View Post
    If that don't work try a fixed ip in the range of your router and change the DNS to Googles. 008 008 008 008 Alternate 008 008 004 004
  12. #11
    Apr 2008
    W Yorkshire
    tried both, dhcp on/off 2 different routers. scr***led
  13. #12
    May 2012
    Quote Originally Posted by mini View Post
    Have you tried changing the DNS?
  14. #13
    Apr 2008
    W Yorkshire
    It does show my thing is online with a tick next to it.
    nope did not try DNS, I'll give it a go later.
  15. #14
    Apr 2008
    W Yorkshire
    It's working
    I didnt have to change anything, all I did was used the dm500 looped the output to the S12. Still not getting few channels like ch5, I've made a no signal fix using a diode but still not getting some channels. The major ones most seem to be working
  16. #15
    Apr 2008
    W Yorkshire
    Been playing baout wiv it and it only works when i connect it through the dm500. Otherwise none of the channels work. I tried the sat feed direct, the same one i use for dm500 and it didnt work, even using the diode fix. This box is b****cks. Dm's are the best. This has truly got me confused.
    Any thoughts people. All help is much appreciated
    Thank you
