Page 10 of 10 FirstFirst ... 5678910
Results 136 to 144 of 144
  1. #136
    Nicolas9's Avatar
    Feb 2017
    Aruba
    if ots oct-2015 its 99% the 35160WT eeprom. if you dont have the original data you will 100% get red dot, no matter what you try. no solution for it. (except if you can read the chip-id from mcu, which probably is close to impossible).
    so to be short. you're f*cked, buy an other cluster..
    NO Selling Please !!
  2. #137
    Apr 2019
    Romania
    I'll use the cluster with the red dot, that doesn't bother me. I intend to keep the car. So I will buy a 35160WT eeprom. And after that? Do I need to flash anything on it? any dump that I can find will do?
  3. #138
    NL
    Hi Friends i thinks CGprog can do it !! they have eeproms they give not red dot but 5 pcs 55 US
  4. #139
    Dec 2010
    hello friends
    need help
    i tryed read 35160WT with r270
    it cant read at me, i clearing legs, and many times not reading....
    i put back to car and now have 0km
    without red dot...
    when i driving with car the odometer count normally up... but need more km....
    have smbdy solution or meet smbdy with this situation ?
    thanx wery much for answer
    j.
  5. #140
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by jordiksvk View Post
    hello friends
    need help
    without red dot...
    j.
    About M35160WT !
    My option............vvdi + xhors 35160 eep and all by ok .
  6. The Following 3 Users Say Thank You to brend For This Useful Post:
    jordiksvk (29th November, 2021), maruti (29th January, 2022), Yhoni (25th October, 2023)
  7. #141
    Feb 2015
    Lincolnshire
    Quote Originally Posted by flop1985 View Post
    Hi all,
    I have an issue with a 6WB retrofit. I have a BMW 2011 bmw F10 (without HUD).
    I bought a used 6WB cluster with HUD from a guy who took out the (i think) 35160wt eeprom. When I say I think it's because the cluster is manufactured on oct-2015.I don't know if it's 35160wd or 16DOW. The other eeprom -95320WT is present . Everyone I ask says that I will get the red dot on the odometer. What are my options? I saw that there is a
    Xhorse 35160DW that eliminates this problem. And what dump should I use?
    Thank you.
    you have a problem, because to use emulator or xhorse chip, you need original chip id
    Stop getting worried about what could go wrong, and start getting excited about would could go right!
    hmmmmmmm........eeprom
    Digi v4.94, Xtool, R260, R270, Smok, VagProg DataSmart 3+ Smelecom, Autel Maxisys ms908, SpeedFilters
  8. The Following User Says Thank You to Dayo For This Useful Post:
    jordiksvk (30th November, 2021)
  9. #142
    Dec 2010
    i removed can blocker from bdc unit and old data was restored on dash....
    thanx for all
  10. #143
    fuzz1's Avatar
    Jul 2019
    I'm trying to look at the datasheet of 35160wt. What makes it so different from other chips?
  11. #144
    Moderator
    PremierD's Avatar
    Jun 2009
    each one has a unique hard ID.....
  12. The Following 2 Users Say Thank You to PremierD For This Useful Post:
    fuzz1 (28th January, 2022), Johnner (27th January, 2022)
