are there any cheaper solution for 35160WT?
I have the new model 6WB with M35160WT and not able to erase the milage on first 2 lines, but i know that not much tools can do it, but i take a empty 160DOWQ chip and i wrote the M35160WT on it with the first 2 lines erased and the Vin erased, but i have the same problem, the cas is not able to write the milage in the Eeprom, so i think my eeprom data is corrupt, because when i make the first 2 lines 00 00 and the rest of the file complete FF FF and nothing else, than the cas is able to write milage in it, but the milage in kombi is 5 km lower as CAS, also driving will not get the dot away. but i can see my correct inspections of oil and brakes, which i could before with the 35160WT chip not.
But i get with istaD an failure of a unknown eeprom version, i gues this is because i make the complete file FF FF, here is my original 6WB maby some one can see if the file is corrupt, because with this eeprom data cas was not able to write vind, also not in 160DOWQ with the same data, only after make whole file FF and first two lines 00 so i think i missed the data, but i delete all because i did not know whats blocking the cas writing milage. can someone see whats corrupt on my file?
ThanksM35160WT_6WB_F10.rar
Stop getting worried about what could go wrong, and start getting excited about would could go right!
hmmmmmmm........eeprom
Digi v4.94, Xtool, R260, R270, Smok, VagProg DataSmart 3+ Smelecom, Autel Maxisys ms908, SpeedFilters
can the chip id be changed to adopt the new epprom?
no you can't.. (not yet..)
so in short there is no way to re-use a kombi with 35160wt? any help is appreciated here
It is possible, but you need expensive tool to code cluster with changed eep
if anyone can do it remotely please pm and i'm interested in the paying for the service. thanks
it cannot be done remotely
All about the Bass
what tool
Reading is fundamental, asking is easy............................
i'm willing to ship if necessary. if you can help please let me know. thanks.
In last update Smok eeprom programmer you can read and write "chip ID"
MCNexo94 (27th June, 2018)
