Page 5 of 10 FirstFirst 12345678910 LastLast
Results 61 to 75 of 144
  1. #61
    Putting reading up will be ok no need to erase
  2. #62
    Nov 2015
    Hereunto yet MRPPAD and R270 and AVDI can't support ( Dxx0D0wT )
    Only D080D0wQ and D160D0wQ and M35xx0Vx ( This types with MRPPAD read/write 5 Second Done In-circuit pcb instrument cluster without remove ic .
    Before edit CAS or to put can filter check instrument cluster eeprom
    i think for this type cars now not have solution
  3. #63
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by Frankcar View Post
    There will be very soon a ''ID'' emulator on the market to solve this red dot problem.
  4. The Following User Says Thank You to drpeter For This Useful Post:
    teerak2uk (7th March, 2017)
  5. #64
    Aug 2010
    It is possible now that a tool can change odometer 2017 g11 yet
    wich tool wich way? Did a can filter work ?
    Wich eeprom Inside ? A guy told from a new chip now. Does any M8 know about this chip
    thnx
  6. #65
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Not possible erase eeprom 35128 from dashboard .
  7. The Following User Says Thank You to cokolo For This Useful Post:
    JFR-Tuning (16th March, 2017)
  8. #66
    Meat-Head's Avatar
    Quote Originally Posted by bmwdd View Post
    so it can read a 35160wt id and then write the id to 160d0wq?
    OFF TOPIC:-
    was playing with myself one, was playing with 95080 25080 & 95P08
    in therory same chip, but only read/write 100/100 selecting correct on.
  9. #67
    Aug 2011
    Hi, I send question about 160D0WT to SMOK and as drpeter said ... he work on emulator ... will use usual 35080
    regards
  10. #68
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    160dwq can erase but 35160dwq not possible to erase
  11. #69
    Aug 2016
    One question..
    i have a 6WB cluster with newer HW and 35160DWQ.
    I know, milage on this eeprom can only erease enigma tool.
    but, does this eeprom have a counter..??
    because, i erease first time the vin and built in a car. allready ok. i erease second time the vin and built in a another car but this time come red dot.
  12. #70
    Oct 2016
    Now I have bmw g ser7 2016
    Is there a way to do it?
    is there can filter
  13. #71
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    i have used stopfilters on g
    Reading is fundamental, asking is easy............................
  14. #72
    Jun 2009
    CZ
    smok 35160wt emu... Wok
  15. The Following User Says Thank You to wokounek For This Useful Post:
    Frankcar (27th May, 2017)
  16. #73
    Oct 2016
    hi
    Where do you get this
    Who sells
    pls
  17. The Following User Says Thank You to Dashfixer63 For This Useful Post:
  18. #74
    smartymarti's Avatar
    Jan 2011
    cornwall
    Quote Originally Posted by Dashfixer63 View Post
    hi
    Who sells
    pls
    There's a clue in the above comment
    All about the Bass
  19. The Following User Says Thank You to smartymarti For This Useful Post:
    dashradio (18th April, 2017)
  20. #75
    Dec 2010
    This is weired: Got a ST160DOWQ from BMW 535 2012. Each time i do an erase, It stops writing 3 bytes from the first 2 lines. These 3 bytes are being 00 and nothing can be written on them. Is there a way to save this chip ? Is there a way to read it's ID (note that this is an old 160DOWQ and not a newer WT) and write it to another ST160DWQ ?
    Any advice will be appreciated !
