Results 1 to 5 of 5
    dominik.m's Avatar
    Jun 2009
    POLAND
    Default MJD 6F3.D1 FIAT DOBLO
    HI ALL.
    FGP 51792923 MJD 6F3.D1 85HP FIAT DOBLO
    Somebody can help Remove DPF with disconnect dif presure sensor and DTC P2452
    salute
    mihaiservice's Avatar
    http://www.quick-tuning.com
    For such file you can do it only manual ! it not a easy job to bypass differential pressure sensor for all kind of ecu MJD6 or MJD8 !
    Even if someone will delete that dtc still will get "check engine" lights !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
    Here you go. Pass in pm.
  4. The Following User Says Thank You to radoslawwiklik For This Useful Post:
    dominik.m (18th March, 2016)
    dominik.m's Avatar
    Jun 2009
    POLAND
    I tried on Your file. After a few km "check engine" lights . No dtc.
    dominik.m's Avatar
    Jun 2009
    POLAND
    I solved problem. I removed only DPF without DTC in file and I exchanged dif-pres sensor on new.
    Thanks for help.
