Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 68
  1. #46
    WALES
    Quote Originally Posted by popov View Post
    Hello it is not correct , maybe someone tried to do something and this serial is different than the serial inside. Here is attached 95640 if it can help. Thank you all for your time!
    Code is not in the eeprom, need to read another device...
    wbr
  2. The Following User Says Thank You to shooting For This Useful Post:
    popov (11th May, 2022)
  3. #47
    Jan 2014
    Default Travel pilot
    So , here is the Flash JTAG read , will be thankful if somebody can share the code.
    If my post was helpful please push the Thanks button and Rep button.
  4. #48
    Readed as gl256 ? Check flash chip, i think it must be gl512
  5. The Following User Says Thank You to neeewww For This Useful Post:
  6. #49
    Jan 2014
    Default correct read
    Quote Originally Posted by neeewww View Post
    Correct - here is the GL512 read /NX/
  7. #50
    ______0547
  8. The Following 4 Users Say Thank You to neeewww For This Useful Post:
    bogege (11th May, 2022), masterskay62 (11th May, 2022), popov (11th May, 2022), smoggy (11th May, 2022)
  9. #51
    Jan 2019
    KG
    Arrow BP0512 code
    Hello mates I need code
  10. #52
    076458C's Avatar
    Jan 2023
    Quote Originally Posted by mrkyboy View Post
    Code is: 5471
  11. The Following 6 Users Say Thank You to 076458C For This Useful Post:
    cheero (13th January, 2023), criollo (13th January, 2023), Decode Ghost (13th January, 2023), mrkyboy (13th January, 2023), pitgamy (13th January, 2023), shooting (13th January, 2023)
  12. #53
    Jan 2019
    KG
    THANK YOU.CODE IS OK
  13. The Following User Says Thank You to mrkyboy For This Useful Post:
  14. #54
    Feb 2012
    romania
    Hello , is it possible to retrieve a code from serial number ?
    ford travel pilot ex by blaupunkt 4m5t 18k931 cc
    SN : BP0514 7 7052957
    7 612 300 514
    Thank you .
  15. #55
    Decode Ghost's Avatar
    Aug 2015
    Quote Originally Posted by cristecristian View Post
    7 612 300 514
    Thank you .
    hi,
    code is 1978.........
  16. The Following 5 Users Say Thank You to Decode Ghost For This Useful Post:
    076458C (13th January, 2023), criollo (13th January, 2023), cristecristian (13th January, 2023), Mankyro (13th January, 2023), shooting (13th January, 2023)
  17. #56
    Apr 2017
    Argentina
    Si te ayudo, solo presiona Gracias y Reputación
  18. The Following 4 Users Say Thank You to criollo For This Useful Post:
    076458C (13th January, 2023), cristecristian (13th January, 2023), Mankyro (13th January, 2023), shooting (13th January, 2023)
  19. #57
    Mar 2019
    Priluki Ukraine
    ford travel pilot ex by blaupunkt 4m5t 18k931 bf
    SN : BP0512 5 5465182
    Thank you .
  20. #58
    076458C's Avatar
    Jan 2023
    Quote Originally Posted by harechko 81 View Post
    ford travel pilot ex by blaupunkt 4m5t 18k931 be
    SN : BP0512 5 5238377
    Thank you .
    Code is: 1131
  21. The Following User Says Thank You to 076458C For This Useful Post:
    petronijul (13th November, 2023)
  22. #59
    Jul 2013
    try code 1131
  23. The Following User Says Thank You to petronijul For This Useful Post:
    076458C (13th November, 2023)
  24. #60
    Mar 2019
    Priluki Ukraine
    BP 0512 5 5465182
