Results 1 to 15 of 70
Hybrid View
    Feb 2010
    WALES
    Quote Originally Posted by popov View Post
    Hello it is not correct , maybe someone tried to do something and this serial is different than the serial inside. Here is attached 95640 if it can help. Thank you all for your time!
    Code is not in the eeprom, need to read another device...
    wbr
  2. The Following User Says Thank You to shooting For This Useful Post:
    popov (11th May, 2022)
  3. #2
    Jan 2014
    Default Travel pilot
    So , here is the Flash JTAG read , will be thankful if somebody can share the code.
    If my post was helpful please push the Thanks button and Rep button.
    Sep 2009
    Readed as gl256 ? Check flash chip, i think it must be gl512
  5. The Following User Says Thank You to neeewww For This Useful Post:
  6. #4
    Jan 2014
    Default correct read
    Quote Originally Posted by neeewww View Post
    Correct - here is the GL512 read /NX/
