Results 16 to 30 of 34
  1. #16
    Lithuania, Vilnius
    Quote Originally Posted by nogger1 View Post
    CORRECTION: I just did another complete software re-install & it only blinking works doesn't it.
    I uninstalled Adobe Reader, went through the registry & deleted all references to Xprog, deleted ALL files previously installed from the RAR file & i ran remove.bat from the PACTH directory. Extracted all files & foldersagain from the RAR archive into the Program Files directory & re-installed & it has read & verified every time, fantastic !!
    Thanks to all who replied with suggestions.
    Nogger1
    UPDATE: spoke tooo soon, still getting verify errors when i write a file, it seems to verify ok after an erase so looks like i will have to reflash the Atmega.
    Hello! the problem comes from virtual Com port setting! Change latency time from 16ms to 1 ms! 100%solution.
    I?siųsta naudojantis MX5 Tapatalk 4 Lt
  2. The Following 3 Users Say Thank You to marrijonas For This Useful Post:
    hansdevogel89 (15th June, 2016), mikajna (16th June, 2016), Rebound (6th May, 2025)
  3. #17
    mikajna's Avatar
    Mar 2015
    Quote Originally Posted by marrijonas View Post
    Išsiųsta naudojantis MX5 Tapatalk 4 Lt
    I need to test that mate, Im hope that will help with verify errors
    UPDATE: It look like its solved, but after few reading same verify errors again...
  4. #18
    Jan 2011
    After reinstallation software Xprog 555 works about 5 times OK
  5. #19
    spiridonas's Avatar
    Quote Originally Posted by Gizbern View Post
    i have too this problem.
  6. #20
    Jan 2011
    Some sellers in my country (no china) have good 5.55 without dongle
    (or can repair Verify Errors)
    We don't have good atmega eeprom and flash !
  7. #21
    spiridonas's Avatar
    The problem with verify errors is the software 5.55 or atmega firmware flash and eeprom ?
  8. #22
    Jan 2011
    Seller likes to send new processor Atmega (cost 50 Euros)
  9. #23
    jakesman's Avatar
    Oct 2013
    Bethlehem Southafrica
    had same story with 5.5.5 downgraded to 5.5.1 and used no dongle software with new usb cable and now all running smooth it was ver 5.5.3 with dongle when i got it so i wnt up up and back down 5.5.1 is stable and no problems
  10. #24
    Jan 2011
    551 is ok, but can't read SPC560 ect.
  11. #25
    Verify error in 5.55 solved!!!Disable internet connection and all OK!!!
  12. The Following User Says Thank You to stas12 For This Useful Post:
  13. #26
    May 2016
    Also,
    try 555 no dongle version, works fine
    it was on this forum somewhere
  14. #27
    araby80's Avatar
    Jun 2013
    INSIDE ECU
    hello can anybody confirm stas12 solution (Verify error in 5.55 solved!!!Disable internet connection and all OK!!!)?????
    cuase i had made downgrade from 5.55 to 5.51 becuase i faced alot of verify erros..
  15. #28
    Jan 2011
    For SPC560 I use 5,55 without dongle
    On other PC, works OK
    Sometimes I get information about Virus
  16. #29
    dadal's Avatar
    Aug 2015
    555 works fine , without dongle,,to find on DK but dont connect internet,,if you 1 time connect then you must install it again, dont works anymore
  17. The Following User Says Thank You to dadal For This Useful Post:
  18. #30
    Apr 2020
    I'm struggling with my xprog box. I can't find the cd and I don't have the software anymore. Can someone attach the software for a chinese clone?
    I was trying downloading it from the internet, but I still get the Safegine error, and it won't start.
    Regards,
    CD
