Results 1 to 9 of 9
    Default UUSP-S system error codes 31 and 997
    Has anyone encountered "system error: 31" and "system error:997" with UPA S programmer? I've been using it with the same computer for quite some time now without any problem. A couple of weeks ago I started getting those errors which come together btw once in a while. Then I started getting it more frequently and now it all the time. I changed USB cables, uninstalled and re-installed the software + driver, it does not seem to help. It passes the HW test successfully. One thing that's strange though is when I get those errors, under connections, the voltages on the pins are hundreds of volts instead of being zero or very low. I think it's a hardware issue. I will be emailing Penko but since he does not answer right away, I figured maybe one of you knows what's going on here.
    Thank you in advance.
    DK Veteran markony79's Avatar
    Jan 2009
    Sweden
    change the computer , and will work fine , becouse i know you have some another tools and driver , which is not work together
    vvdi ?
    this errors is for voltage ....check it on upa coection...will show 999v ...is it right ?
    Why change the computer? I don't think it's a driver conflict. It does the same thing on my laptop. And yes it shows crazy voltage.
    May 2011
    hi
    change usb cable and all ok
  5. The Following User Says Thank You to digimile For This Useful Post:
    frontpager (19th March, 2022)
    DK Veteran Matttes's Avatar
    Mar 2016
    I solved this problem uninstall old drivers from Elrasoft, install new last drivers and change USB cable. I have usually one cable for ne, or two month.
    I have more interfaces.
    From changes work perfectly.
    Jan 2009
    Sweden
    believe me, i know about this errors,
    change the pc and will work good....100%
    i know you , but maybe you was forget me ..... you are in chikago ?
    we was talk before
    Quote Originally Posted by markony79 View Post
    we was talk before
    I think you did not read my post (#3). I did change it...same thing happens on that other computer. Error 997 is overlap I/O problem... so when you get the same error on a different PC and with a different USB cable then chances are it's a UPA hardware problem.
    And I remember you. But I'm not from Chicago.
    May 2018
    Hello, friends end sorry from my english. I need help with upa usb clone. Thanks...
    UPA-USB Device Programmer v13014
    Licensed to: Xinbo Zhang
    System: Microsoft Professional (build9200), 64-bit
    Detecting UUSP...Pease wailt!
    Device Description: ELRASOFT UPA-USB3.0 Driver (1.2.2.00, 12/20/2012)
    USB Driver Name: UPAUSB.sys, FS Mode
    5V Tests. Close J1 and press a key to continue
    Test1: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Result: P1=0,00V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
    Test Passed
    Test2: P1=8V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Result: P1=8,19V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
    Test Passed
    Test3: P1=9V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Result: P1=9,23V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
    Test Passed
    Test4: P1=10V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Result: P1=10,07V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
    Test Passed
    Test5: P1=11V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Result: P1=11,10V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
    Test Passed
    Test6: P1=12V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Result: P1=12,18V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
    Test Passed
    Test7: P1=13V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Result: P1=12,94V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
    Test Passed
    Test20: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=5V
    Result: P1=0,00V, P2=1,37V (L), P3=0,00V (L), P4=0,00V (L),P6=4,25V (L), P7=0,00V (L), P8=0,00V (L), P9=5,09V
    P2(1,37V ) not in 3,00V - 4,00V
    P6(4,25V ) not in 3,00V - 4,00V
    Test Failed
    Test21: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=5V
    Result: P1=0,00V, P2=0,06V (L), P3=0,00V (L), P4=0,00V (L),P6=0,06V (L), P7=0,00V (L), P8=0,00V (L), P9=5,09V
    Test Passed
    Test22: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=5V
    Result: P1=0,00V, P2=5,04V (L), P3=5,08V (L), P4=5,11V (H),P6=5,08V (H), P7=5,09V (L), P8=5,09V (H), P9=5,09V
    Test Passed
    3.3V Tests. Open J1 and press a key to continue
    Test40: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=3.3V
    Result: P1=0,00V, P2=0,98V (L), P3=0,00V (L), P4=0,00V (H),P6=3,14V (H), P7=0,00V (L), P8=0,00V (H), P9=3,61V
    P2(0,98V ) not in 2,50V - 3,30V
    Test Failed
    Test41: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=3.3V
    Result: P1=0,00V, P2=0,05V (L), P3=0,00V (L), P4=0,00V (L),P6=0,05V (L), P7=0,00V (L), P8=0,00V (L), P9=3,61V
    Test Passed
    Test42: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=3.3V
    Result: P1=0,00V, P2=3,56V (L), P3=3,61V (L), P4=3,61V (H),P6=3,59V (H), P7=3,61V (L), P8=3,61V (H), P9=3,61V
    Test Passed
    Test60
    950D5A5B67938399
    Test Passed
    2 Tests failed
  10. #9
    Junior Member telegu's Avatar
    Dec 2016
    1. Change the USB cable with one new and very short one.
    2. In PC, go to DeviceManager and uninstal the driver. Now , reinstall the driver manually ,restart PC ,connect the interface, run the software and test.
    3. If not work, change the capacitors on the PCB with a new ones.
    good luck!
