Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
  1. #16
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    anyone confirm what pinout is the right one please ?
  2. #17
    luca22's Avatar
    Dec 2010
    My and Your Pinout is the same, but two 12v pins less on your diagram.
    I always connect ECU with my pin-out and works 100%
    If ECU atart communication only at two 12v, I think another is not needed
    EDIT: ground pin is ok , just in case, take the electric meter and check for transition!
    Luca
    PLEASE PUSH THE BUTTON THANKS IF MY WORK HAS HELPFULL
    AND REPUTATION BUTTON (starr)
  3. The Following User Says Thank You to luca22 For This Useful Post:
    smirnoff_rules (26th October, 2016)
  4. #18
    Mar 2008
    birmingham
    l will try yours next time then thanks .. l flashed back the same way l read in the end as it was all setup
  5. #19
    Aug 2019
    kess obd II.jpgwhich is that little black wire? k-line? I need to connect xc90 2.4d5 2007.
  6. #20
    Dec 2018
    ? i have same question
  7. #21
    Jan 2020
    Default Hi i can`t see your jpg
    Quote Originally Posted by Tomanio View Post
    I build connector from old engine wirring for that ECU so read and write takes max 2 min that is pinout- works 101%!
    Attachment 366562
    the picture of how you fix the problem regarding Volvo XC 90 are impossible to enlarge.
    Can you mail it to me
  8. #22
    Jan 2020
    Hi I manage to fix the picture, but need some more information about the connector you made, and how you use it. I ques you take out the ECU from the car.
    What is the best way to do that procedure.
  9. #23
    Jan 2020
    Norway
    https://www.ebay.com/itm/Kess-Volvo-...0AAOSwnhldVueY
    Solution to all your problems.
    Obd id,read,write ok, edc16 1.6hdi.
    Kess V2.47 Eu.
    Ok price, covers quite a bit of volvos.
  10. #24
    Jan 2020
    Norway
    This is 12v+ bat when needed.
  11. #25
    May 2019
    Attachment 366562
    and with that scheme could you read volvos with kess?By obd2 I do not leave you?
  12. #26
    Dec 2022
    Yes , the free connector on the ODB cable is connected to the KESS Kline, and you can use the blue cable to connect it on the ECU connector pin 43.
