try to read first and check if is good
In volvo inside OBD plug not K-line in 90% cars!
That ecus remap via K-line!
You must take out ECU and remap at table.
giegaand1 (25th January, 2020), HeXeN (21st January, 2019), Motocross271 (22nd January, 2020), superpelman (26th March, 2016)
agree with Babos, majority will never work on obd
For sure, edc16c31 not in obd, only in table, or connect direc kline to ecu, with car plugged in the car.
And not all ecus posible.
Gentelmens!!!!
Volvo 163 HP is edc15 or edc16, if edc15 I always desolder 29f400, mod and solder, because I tried many times and always read not problem but write never, if edc16 it's enaugh push the needle in 43 pin and connect k-line
so ecu must be on car for k line read ? I tried on bench once without success..
i use to do them by bdm, which is very risky...
I build connector from old engine wirring for that ECU so read and write takes max 2 min that is pinout- works 101%!
Volvo Electronics Enginering
CEM Config change, virginize modules , keys programing...
our ecu edc15 and edc16 in Volvo you read and write on table, I do Volvo and never open ecu, never....
to make synchro or to copy you must open...
l had one in today kessv2 wouldnt read it with the right cable going to kline and power+earth kess was showing 3v ?
tried kess on obd on golf and works fine .. its a eu clone
in the end fgtech read fine with kline in and powered up but not happy kess didnt work , read afew post saying kess didnt work afew times ? anyone else?
What is the problem with removing the ECU on the table and connect the pins for it?
after what you make life difficult?
Oryginal Kess v2 reading this without any problem, whether it's XC90 or s60, s80 and Galletto or MPPS EU to ...
The OBD connector in Volvo has no K-line and the fastest way is to read and write this ECU is take it on the table, connect pins and working on it
Luca
PLEASE PUSH THE BUTTON THANKS IF MY WORK HAS HELPFULL
AND REPUTATION BUTTON (starr)
97anton (2nd February, 2020), smirnoff_rules (25th October, 2016)
my pin out pictures didnt show them just 5 power 6 earth then small power and kline and when connected 12 on supply dropped to 5v
