Page 1 of 6 123456 LastLast
Results 1 to 15 of 78
    ibratex's Avatar
    Jul 2015
    angola
    Default URGENT HELP !!! NEEDED
    I have made the mistake in trying mileage correction by FVDI
    On MERCEDES SLS 63 2013
    now the car cannot start with the start button ... it starts with they key in EZS on back of console thats a good part
    And check engine light came up
    BEFORE I TRY MILEAGE CORRECTION I SCANNED THE CAR AS SLS W197 2010-
    USING FVDI AND IT SHOWED UP ALL DTC NORMALLY AND CONNECTED TO WHOLE MODULES
    NOW WHEN I SCAN IT ONLY CONNECTS TO CENTRAL GATEWAY WITH NO DTC
    PLEASE FIRST I AM UNABLE TO LOCATE THE PROBLEM BUT I THINK ITS ASSYST PROBLEM
    PLEASE HELP WITH WHATEVER YOU GOT ...THANKS
    Sent from my SM-G850F using Tapatalk
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by ibratex View Post
    My friend people Warned you for this, i cant help you on this but i think there are similar posts about fvdi en MB.
    Good luck.
  3. The Following 2 Users Say Thank You to honingkoning For This Useful Post:
    ibratex (26th March, 2016), mikroel (12th May, 2016)
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    did u try to disconnect both batteries
    Reading is fundamental, asking is easy............................
  5. The Following User Says Thank You to XmoDDeR For This Useful Post:
    hark87 (3rd April, 2016)
  6. #4
    ibratex's Avatar
    Jul 2015
    angola
    Quote Originally Posted by XmoDDeR View Post
    I see 1 battery where is the location of the other
    XmoDDeR's Avatar
    Mar 2011
    recode wit star , fix broken communication.
  8. The Following 2 Users Say Thank You to XmoDDeR For This Useful Post:
    BYTES (26th March, 2016), ibratex (27th March, 2016)
  9. #6
    pepesound's Avatar
    Bulgaria-Radomir
    http://www.digital-kaos.co.uk/forums...-recalibration
    my friend,
    you should buy a very different technique to touch so serious automobile, you will not get away with just € 1,000
  10. The Following 2 Users Say Thank You to pepesound For This Useful Post:
    ibratex (27th March, 2016), Rito (4th April, 2016)
  11. #7
    dave11674's Avatar
    Florida, UK
    you have fluffed up the front SAM mate
    either take it out and erase it
    or code it back in with star
    there is a recovery method on orig AVDI
    good luck with this
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Smok PSA, volvo & ford
    If someone helps you DONT FORGET TO SAY THANKS its only polite....
  12. The Following 3 Users Say Thank You to dave11674 For This Useful Post:
    ibratex (27th March, 2016), mikroel (12th May, 2016), smokey08 (27th March, 2016)
  13. #8
    Gavra's Avatar
    Belgrade/Melbourne
    Good luck.........But I still do NOT understand why would someone do that after asking in different topic and still do it your way...... Be careful because with STAR you can kill it completely if you don't know what you are doing ....
  14. The Following User Says Thank You to Gavra For This Useful Post:
  15. #9
    ibratex's Avatar
    Jul 2015
    angola
    thank you all for helpin out ... after i did some searches beside your helpfull kind disscusion
    i saw that coding again is the solution but in here the dealer is a lot expensive option ... so i managed to arrange maxisys autel after i saw that it is able to do online coding on some youtube videos but didnt test yet .
    Beside this in diagprog guide to mercedes recaliibration says :
    Resolving troubles : when programming process brake (because of car battery)
    - communication will beginfrom the same point in next programmation
     if on next programmation is no communication with the car is necessary to disconnectboth car batteries (front and rear) , connect again and return to the car programmation all times after programmation is necessary to erase DTC's in the car.Warning !!! DiagProg III user can't program other cars until car with broken programmationwill be finished ! In case of programming new car all backups may be lost !Sometimes car battery have to be disconnected for few minutes (cars equipped with more thanone battery need to disconnect all additional batteries).
    MY question now , i located the battery big one in the front right motor side but i need your help in finding the second battery , i am unable to find it i already checked trunk and front . is there any way with picture please?
    thank you again mates
  16. #10
    DUPNICA BULGARIA
    Find someone with avdi or dp an repeat procrdure with flashing again. FVDI write new flash in to gateway-instaling software can blocker. Naw gateway is dead and you dont have comunication. Try again to change km (reflash gateway). Other way is to find bacup flash and to whrite back. Try. Online coding is next solution.
  17. #11
    First, if the battery in the front is a big one then there's no secondary battery. Second, you cannot use the Diagprog to fix it as you did not do the programming with it in the first place (=no file saved). Indeed Diagprog can continue programming where it left off in case it times out... which was not the case before. Also, if your engine fan is not spinning fast, your turn signals work for example, it means the xentry can still communicate and reflash the gateway. I always do programming and scn coding online so I wouldn't be able to help you with doing it offline.
    But one advice though: if you wanna play with expensive cars like that, (aside the knowledge and experience) you need to have 1) the proper tools- I mean the real deal- not some chinese clones, 2) the money to cover the cost of replacement parts if damaged beyond repair, 3) the connections at the dealerships to have them fix it through the back door... because in many countries they would (red) flag the car and void the warranty if they find out there was some manipulations. They always call an engineer when something's suspicious with an AMG.
    Good luck.
  18. The Following 2 Users Say Thank You to Speedosoft For This Useful Post:
    Berubeg (27th March, 2016), rimniceanu (3rd April, 2016)
  19. #12
    Jan 2016
    what have you exactly made with fvdi? have you put "yes" when it ask you if you want to block sync?
  20. #13
    ibratex's Avatar
    Jul 2015
    angola
    Quote Originally Posted by paftec View Post
    Yes i did
  21. #14
    ibratex's Avatar
    Jul 2015
    angola
    Quote Originally Posted by ilian_cho View Post
    Yes its logic ..but while messing in front sam fuses i took out thre fuses randomly then put it back then tried start with start button the car clicked just once thats why i am trying to locate second auxilliary battery to remove but cannot find .... and finding someone with avdi is difficult here my freind i am the only i know even with fvdi ... ... thank you
  22. #15
    dave11674's Avatar
    Florida, UK
    the man above said if the battery is in the front where urs is then it dont have a secondary battery
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
  23. The Following User Says Thank You to dave11674 For This Useful Post:
