Page 5 of 6 FirstFirst 123456 LastLast
Results 61 to 75 of 78
  1. #61
    ibratex's Avatar
    Jul 2015
    angola
    Quote Originally Posted by garabounga View Post
    Did you contact DK member MIN2XX ? he is the ZGW specialist maybe he got a solution for you i think when they tryed to update they corrupted the file.you can try what you deed before to start the car if flash not corrupted.
    For the files go to windows startbutton ----surchbutton -----type fvdimercedes maybe you can find the file
    Yes i contacted him and waitin answear
    Sent from my SM-A700YD using Tapatalk
  2. #62
    ibratex's Avatar
    Jul 2015
    angola
    The Car shows no faults in CGW
    But all modules show bad comunication with the central gateway
    Any idea mates???
  3. #63
    ibratex's Avatar
    Jul 2015
    angola
    And it's not reading anymore eeprom nor flash
  4. #64
    ibratex's Avatar
    Jul 2015
    angola
    This time good news solved again and all active normally
  5. #65
    hass42's Avatar
    Aug 2012
    USA
    How did you solve?
    Hass42
  6. The Following User Says Thank You to hass42 For This Useful Post:
    ibratex (2nd April, 2016)
  7. #66
    May 2015
    deleted��
    Sent from my HTC One_M8 using Tapatalk
  8. The Following User Says Thank You to Nymike For This Useful Post:
  9. #67
    Dufner
    Johnner's Avatar
    Éire
  10. The Following User Says Thank You to Johnner For This Useful Post:
  11. #68
    ibratex's Avatar
    Jul 2015
    angola
    hello hass , i took out the 95080 from the bosch unit ecu then changed the dump to 0000 it didnt work , then i put back the same dump i found again to ecu ... the car started normally , now i didnt understand why and how but it is good for now , and all function came back with start button and so on .... and now i am not sure that the car will always be good , there is somthing wrong wrong leting the modules lose comunication hope that dosent happen ,, any one experienced this ?
    i found in fvdi option for viginizingg the ecu 95080 this will be next ssolution since now i am not sure it will be good for long
    now its not the fvdi problem , now its xentry coz all wat happend now is after xentry flash cgw and update
  12. #69
    ibratex's Avatar
    Jul 2015
    angola
    i deleted yes
  13. #70
    ibratex's Avatar
    Jul 2015
    angola
    hass42 i am not sure will be alrigt because i hade the error code
    u116000 a bus keepwake unit was detected
    and this code as i understood is about temperature status that triggers a pyrofuse somwhere and prevent car from starting
    http://workshop-manuals.com/mercedes...ms/page_13441/
    this link is an idea about what i mean if you had the time please read
    thanhks all
  14. #71
    Quote Originally Posted by ibratex View Post
    New cgw and frontal Sam???
    To my knowledge there is no separate N93 (central gateway) on the W197. It's part of the N10/1 (Front SAM). Replace the front SAM and have it programmed by the dealer. Or you can replace it with a used one, the VIN in it will not conflict at all and everything will back to normal. Although I believe you're gonna have hard time finding a used one in your area.
    Also, it's very common for a gateway to show no fault but not communicate with the modules. Faults are stored in the eeprom but the running software is in the flash. It is your flash that's corrupted!...and mostly the basic software area. All the sypmtoms and problems you see such as a faulty ECU, windows not working etc etc are due to the gateway. In medical field they call that a referred pain (source is elsewhere than where it's actually felt), the source is the gateway here (built in the SAM) but the pain are felt in the other modules. now you can spend days and weeks trying to fix it or better you can replace it with a new one; and figure out later what happened. By the way, your customer must be a very nice to be so patient.
  15. The Following 2 Users Say Thank You to Speedosoft For This Useful Post:
    ibratex (2nd April, 2016), Skrillex (13th April, 2016)
  16. #72
    ibratex's Avatar
    Jul 2015
    angola
    Quote Originally Posted by Speedosoft View Post
    To my knowledge there is no separate N93 (central gateway) on the W197. It's part of the N10/1 (Front SAM). Replace the front SAM and have it programmed by the dealer. Or you can replace it with a used one, the VIN in it will conflict at all and everything will back to normal. Although I believe you're gonna have hard time finding a used one.
    Ok thank you speedo
  17. #73
    No problem and good luck as this must be very stressful.
  18. The Following User Says Thank You to Speedosoft For This Useful Post:
  19. #74
    ibratex's Avatar
    Jul 2015
    angola
    The Car is ok till now.. No stress
    It was very stressful bro but the solution was easy thanks
  20. #75
    Mar 2015
    Is every thing back to normal now?is car back to owner?
