Results 1 to 5 of 5
    dave11674's Avatar
    Florida, UK
    Default Corsa D 2007 1.7cdti running problems !
    hi
    can anyone help out here
    spent all day in this car reprogramming the ecu and various modules
    even flashed the ecu with tech 2 as it had a newer file in there for this ecu.
    so basically my mate dropped his car off with me as it starts up fine
    runs for a few seconds then cuts out
    sometimes runs for 10-20 seconds then cuts out
    does anyone know if this engine has the fuel pump ecu on the back of the engine like the older 1.7 cars did that had the problems arise in there !???
    you can drive the car even
    but as soon as you stop it cuts out
    any help here greatly appreciated
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Smok PSA, volvo & ford
    If someone helps you DONT FORGET TO SAY THANKS its only polite....
    gaz306's Avatar
    Jun 2010
    Gods Country
    Had exact same bother recently , though this was 2007 1.3 cdti , tried all sorts , turned out it was the injectors
    Mar 2013
    This is a common rail fuel system and does not have a dedicated fuel pump control module
    If the car drives ok under load and all other driving conditions other than idle, with no fuel pressure issues.... From your symptoms I would say 100% you have a faulty fuel pressure control regulator
    Jun 2010
    Norfolk england
    Any fault codes? Check for water damage in ECU.
    Sent from my iPad using Tapatalk
    Add life to your days not days to your life
    P
    dave11674's Avatar
    Florida, UK
    Only fault code relates to glow plug elelctronics low voltage
    cant see that been a problem
    Where is the fuel pressure control reg ?
    thanks guys
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
