Results 16 to 30 of 40
  1. #16
    Default dump for black screen?
    Quote Originally Posted by simaservis1108 View Post
    Actually,problem lies in the ST10.
    It is the one who controlls CANbus functions and acts as an Audio Gateway.
    Hi do you have dump for black screen problem on continental unit?
  2. #17
    Jul 2016
    I can confirm that sonices solution worked for me
  3. #18
    Aug 2015
    No, I just want to know if anyone already suceess to solve this problem ?
  4. #19
    Aug 2015
    Quote Originally Posted by Clodius View Post
    Hey you solved this same problem as me after replacing chip ?
  5. #20
    Jul 2016
    I didn't replace the chip, but did a bypass
    Sent from Tapatalk
  6. The Following 7 Users Say Thank You to Clodius For This Useful Post:
    asliyucegsm (30th December, 2018), Boldy4 (13th September, 2018), dekoderi (17th December, 2017), marian.m (27th November, 2016), Papiti56 (2nd April, 2021), popov (29th December, 2018), vavrich (30th March, 2020)
  7. #21
    Sep 2016
    Hi d3signz,
    I would like to ask you regarding the solve problem with can comunication RNS with car.
    How you solve this problem. Did you replace new chip or like is in last thread ??do baypass on chip??
    Many thanks for your reply
  8. #22
    Jul 2016
    either solution works, but it's faster to do the bypass
  9. #23
    Mar 2018
    What all does the TJA1055T chip handle. RNS510 "C" version. Audio and some other functions
    My symptoms: No sound, no sound when playing with either HDD or SD card or CD, no song timer count down, can't upgrade firmware from 1140 to 2680 and when I try it errors with SWL 010303 and does not finish, I can see the radio is locked onto a station but no sound. Everything else works well. Speakers do pop when the system is starting up but no sound.
    Help.
  10. #24
    Sep 2018
    Hungary Eger
    Hello Clodius,
    I did a bypass on the chip, but I detected that the RNS 510 not starting automatically anymore. ( if the car ignition is on ) I need to turn on manually,after that the all system is working well. Do you have any solution for this issue?
  11. #25
    Jan 2014
    Hi all , can someone tell me what is the amount of the resistor in the red circle?
    Thank you in advance and happy new year!
  12. #26
    siti's Avatar
    RO-ALBA
    Quote Originally Posted by popov View Post
    10k....................
  13. The Following 7 Users Say Thank You to siti For This Useful Post:
    asliyucegsm (30th December, 2018), catalinosonesti (5th September, 2020), kappa1 (30th December, 2018), masterskay62 (30th December, 2018), popov (30th December, 2018), shooting (30th December, 2018), yahia1908 (22nd April, 2020)
  14. #27
    Dec 2017
    Can Bus Problem is often solder Problem
    take a look at the smd ledge which connects the radio and the skin plate usually the outer pins have to be re-soldered
    This is vor Old lcd Units
  15. #28
    Feb 2019
    Quote Originally Posted by Boldy4 View Post
    Hello Clodius,
    HI all. I have the same problem as Boldy4.
    Please, help me solve it.
  16. #29
    Mar 2019
    So, there is another fix needed instead of bypassing VCC and BAT on TJA1054 ?
  17. #30
    Mar 2019
    would this solution solve my issue? My rns 510 on initial startup works fine and i can keep it on for hours, but if I shut it off for 10 mins or more and come back to my car the head unit is completely dead and remains dead until several hours later. I've checked all fuses and connections and the problem remains. I'm only assuming its an internal issue of some kind. My part # is continental - 3C0035684C SW 1140.
    Also when My unit is dead there is no audio, backlighting, or control through MFD but MFD shows bluetooth connection to phone! but with no audio it's useless.
