I have problem with megane 1,9DCI EDC16C3, after write software with EGR off with KESS clone, I have permanent on SERVICE light on dash, no DTC's at all, car is running without problem. Allready try to write back original dump by OBD then I found full BDM backup and write original dump, same result. allready try to recode injectors with KTS and then CLIP, no result, I suspect that there is problem in eeprom, tryed to make virgin and recode but then I have P0606 DTC and some injetors not coded DTC, and can't code anything even with CLIP.
Is there someone that had sumilar problems and can help me, here is my eeprom dump
yes, there is cruise control, why?
Try poking the cruise switch with a stick..see what happens ..
A failure will not appear till a unit has passed final inspection
Shmortz (6th April, 2016)
hm, interesting, I will try tomorrow
... cruise buttons are on the steering wheel...
Nice tit.... ;-) All want help you / dont say that's only some avatar haha /
Any error before virginization ?
1. You make EGR off because some errors on ecu - check engine light on
2. After writing chk engine dissapear but still service light ?
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
DashProg (6th April, 2016)
thanks for helping me, sorry but it's only avatar...
the car have problems with egr sometimes, but in that moment before write egr off dump there was no light at all, after flashing service light lit permanent, the reflash with ori, same result, then found full bdm and open ECU and flash, same result, car is runing without problem but with service ligh on... today i tryed with other eeprom, immo virgin and resync, injectors recode and in the end same result, no DTC but light on...
oohhh !
Did u have Can CLIP ? Check DTC in instruments and all stored values for oil changes etc..
And on ecu that's same
I can use can clip and I tryed to found out what happend but didn't found any stored values in ECU, there is no DTC's in any module in car...
First spam pinotec thank button and leave the steering wheel buttons alone,the one on the dash cruise/limit is the one to poke...
pinotec (7th April, 2016)
what is the idea with poking, and in what moment need to do that? I don't think there is such button on dash...
OK, near the light dimmer/headlight adjustment and if fitted esp button
One can just push it but is much funny to poke it..
Understand now, and if I push it service light must go off ?
Ign on or engine started, poke or push once on limit once on cruise
That should do it
I will try tomorrow, thank you all very much!
