Results 1 to 3 of 3
    May 2008
    Default SQLite EPG Freezing 500s at startup
    Hi guys,
    Since EPG Evolution closed down its server I decided to try SQLite EPG on my 500s running Jade 3.
    I set up a mount point on my PC and downloaded SQlite and configured it to download the Radio Times EPG.
    I then mapped the channels and retrieved the data and it was working fine.
    However when I turned on my 500s the following day it just hangs at the bootup stage .
    I had to reflash with Dreamup and had to redo the EPG stuff .Worked grand agin until I powered it on the nest day,same freezing.
    It must be some sort of bug as the receiver works fine without the SQLite installed.
    I wonder is it a mount issue or is it just too much data for the 500s to handle ?
    Any ideas are greatly appreciated.
    Cheers
    May 2008
    Ok Guys,I figured it out after a bit of head scratching.
    My router (when rebooted )was changing the IP address assigned to the pc with the hard drive mount resulting in the dreambox going into a loop as it could not find the hard drive.
    I assigned a permanent ip address to the pc and it works ok now.
    Might be of help to some other people .
    Feb 2008
    fano do you have a tutorial no how to set SQLite EPG up on a pli image just about to search and google now just being little lazy dreambox 7020si original 320 gig HD
