try flash with ista/p or remove dtc form flash if car run well
So car was bought with this dtc.
It gives dtc 46D1 (Internal computer fault) The ecu number is 0281012334 DDE 7797497 1037372963
Does anybody have a good bdm eeprom file for this ecu or a solution to solve this? Virgin file or something?
BMW320D e90 EDC16
bmw320d.zip
will pay for solution
MV auto (7th April, 2016)
Can you read out full BDM and post here so we can see can we help with your file?
Here is you original eeprom repaired.
antonypaul (13th December, 2023), donesko (8th April, 2016), geeroam (20th May, 2016), lari95400 (4th November, 2017), vanos batam (8th April, 2016)
Hi Smokey Can you check my file too please i have same vehicle same problem thanks
Here is you file with checksum repaired. Looks like someone has deleted VIN.
antonypaul (13th December, 2023), geeroam (21st May, 2016), lari95400 (4th November, 2017)
will post results
Thanks Smokey it worked
can someone help me. since ive had my 330d e46 remapped i keep getting p1640 fault code eeprom config code. I will attach my original file and tuned file.can anyone find anything wrong with these? thank you
ps: i have inpa DIS MPPS etc just in case i need to flash or scan ecu etc
Hi, can I get this one fixed too? same error ! 46D1 !!!
75E put FD
75F put 23
Hi, it didn't work ...!Error is still there!
