If there is regeneration, the smoke will be white, not black...
You can check with VCDS, is there a post injection...
Regards!
Regards!
Yeah like bobolino say, make diagnostic.
Turbo or injector problem is possible.
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
A fellow can check whether the solution is well DPF OFF?
Send the original file.
Original and modified in Annex in the first post.
I switched only 1D4030 for DPF off and it works
What are 1EE9FC and 1F2E55 ?
DPF OFF by switch its not allways good idea in VAG cars. white-black smoke on idle, more consumption of fuel on idle ( about 1,2l/h).
CHIPTUNING, ECO-TUNNG CARS TRUCKS BIKES,
EGR OFF, DPF OFF, NOX O2 KAT OFF, SWIRL FLAPS OFF, THROTTLE OFF, MAF OFF
DTC OFF, LIMP HOME MODE OFF!!!
ADBLUE OFF, SCR OFF, ADDITIVE OFF, CNG OFF, SPEED LIMTER ON/OFF/SET
HOT/COLD START
CRC FIX - FULL GENUINE WINOLS FULL CRC / SWIFTEC FULL CRC
TRANSLATE DAMOS ENG
COUNTER FIX - VAG EDC16, EDC17
ORYGINAL FILES DATA BASE
START/STOP ON/OFF
LaraVAG dpf is not turned off the switch. Just look at the attachment. I know that there are problems in crafter as a solution with a single switch.
