Results 1 to 6 of 6
Hybrid View
    t77's Avatar
    Poland Lodz
    Default Vectra C dpf off and egr off
    Hello I need dpf and egr off in Vectra C 1.9 cdti ECU EDC16C39
    Please some help
    Dec 2012
    for corect dpf off in edc16c39 must full bdm mate
    mihaiservice's Avatar
    Dec 2009
    http://www.quick-tuning.com
    Fiat/Alfa can be done egr off with obd file,why not also opel ?
    here you have dpf off and egr off file,you can disconnect the plug from differential pressure sensor also plug from egr
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  4. The Following 5 Users Say Thank You to mihaiservice For This Useful Post:
    Apsik (2nd September, 2016), blazej1200 (12th April, 2016), bobolin4o (15th September, 2016), suzy46 (22nd May, 2016), t77 (12th April, 2016)
    Sep 2016
    Hi, I need this to.
  6. #5
    bobolin4o's Avatar
    Apr 2010
    Bulgaria, V. Tarnovo
    Quote Originally Posted by MobyDavid View Post
    Hi, I need this to.
    Really???
    And who are you, where you from, what is your occupation etc?
    NO PASSWORDS FOR ANYONE, EXCEPT THE RECIPIENT OF THE FILE !!!
    If your PM box is full, clean it right now...
    Otherwise, your requested file will be deleted... for ever!
  7. The Following User Says Thank You to bobolin4o For This Useful Post:
    drewdom (15th September, 2016)
  8. #6
    bobolin4o's Avatar
    Apr 2010
    Quote Originally Posted by mihaiservice View Post
    Fiat/Alfa have only one code block in the flash, but Opel may have up to 3...
    Trough OBD you can read only 1 of them (bottom of the file) and it is a matter of luck if current ECU use exactly this one...
    BUT... if you have a full flash, exactly the same SW (BDM read), you can flash it through OBD...
  9. The Following 2 Users Say Thank You to bobolin4o For This Useful Post:
    auto4 (8th April, 2017), nom (15th July, 2020)
