Vectra C dpf off and egr off
    t77's Avatar
    Poland Lodz
    494
    Downloads
    10
    Uploads
    Default Vectra C dpf off and egr off
    Hello I need dpf and egr off in Vectra C 1.9 cdti ECU EDC16C39
    Please some help
    Dec 2012
    7
    Downloads
    85
    Uploads
    26
    for corect dpf off in edc16c39 must full bdm mate
    mihaiservice's Avatar
    http://www.quick-tuning.com
    162
    Downloads
    47
    Uploads
    Fiat/Alfa can be done egr off with obd file,why not also opel ?
    here you have dpf off and egr off file,you can disconnect the plug from differential pressure sensor also plug from egr
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  4. The Following 5 Users Say Thank You to mihaiservice For This Useful Post:
    Apsik (2nd September, 2016),blazej1200 (12th April, 2016),bobolin4o (15th September, 2016),suzy46 (22nd May, 2016),t77 (12th April, 2016)
    Sep 2016
    Downloads
    Uploads
    Hi, I need this to.
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    908
    Downloads
    6
    Uploads
    Quote Originally Posted by MobyDavid View Post
    Hi, I need this to.
    Really???
    And who are you, where you from, what is your occupation etc?
  7. The Following User Says Thank You to bobolin4o For This Useful Post:
    drewdom (15th September, 2016)
  8. #6
    bobolin4o's Avatar
    908
    Downloads
    6
    Uploads
    Quote Originally Posted by mihaiservice View Post
    Fiat/Alfa have only one code block in the flash, but Opel may have up to 3...
    Trough OBD you can read only 1 of them (bottom of the file) and it is a matter of luck if current ECU use exactly this one...
    BUT... if you have a full flash, exactly the same SW (BDM read), you can flash it through OBD...
  9. The Following User Says Thank You to bobolin4o For This Useful Post:
    auto4 (8th April, 2017)
