Do you have original adapter? check pinouts if they are same with the probe then you can use it if not just solder it. Be carefull it is delphi reversed for this ecu.
Sent from my SM-A510F using Tapatalk
I would like to read a DCM 3.2 from Mercedes c200 W204.
BDM100 seems to not support it because it's older than the car.
I have official trasdata, but not official delphi bdm probe.
Do you think that is compatible ? Is there any risk to try ?
You can find in attached files, pictures and pinout
Thanks for your help.
I do not have original dimsport probe.
I put you a picture of original compared to mine..
Yes delphi reversed that why I do not want to do a mistake and take the risk of try
Didn't this adapter came with your tool? http://www.tuningfiles.com/14as00t04...la-mpc5xx.html
Ok, will check If I have it..
Found this : (on bdm100 original documentation)
I have this adapter with trasdata..
I have to compare pinout with my delphi prob
If it's not match I will solder this adapter on pcb
But pcb seems to have varnish on it.. is it easy to solder ?
Sure it's easy
Great
It is 646evo CRD11?
Yes
The RED circle is 12V Power cable on adapter ;-)
But it is enough when you give 12V on the ECU Pinout ;-)
DjRomeoR (17th November, 2018)
