sshiref11 (9th October, 2022)
Im need a little help guys
i have to reflash my xprog clone 5.5.5
i have a USB ISP USBASP Programmer AVR which is from ebay
software im using extreme burner.
im using files form http://www.digital-kaos.co.uk/forums...ht=xprog+5.5.5
post 18
vanos batam
when im loading the .bin files i get error in software.
im needing to select .hex files to load in to software to programe the atmega64
either i need to have hex files atmega flash and eeprom or im doing someting wrong?
ive looked at files for xprog 5.0 posted on here and they are in .hex format and load correctly into extreme burner..
anyone have a different way to do with the files i have and the tool i have... maybe a different software
any info would be great.
ive searched and searched
please could someone help.
anyone ???? help??
Xprog 5.55 hex
xprog.rar
madbg (25th March, 2021)
Hi man,
here atmega files work ok 5.55 ver. Remember erase flash mem, erase eeprom mem, set fusebit, program flash mem, program eeprom mem.
if need soft, i can upload.
regards
pass PM
eduardo131 (3rd February, 2017), gbratk (23rd August, 2016), houdiag (31st October, 2016), just4upal (2nd November, 2016), kadi0209 (29th November, 2016)
motpass please
i dont can understand for what raison use USBASP.can make this work very easy with UPA,easy and safe.
Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
mates... i goto ver 5.51... 5.5.5 is not good, very unstable...
5.5.5 runs fine releasesd on mmh originally. Your not setting you fuse bytes right??? It only likes to run on xp.
He has 5.7.6 but not public. They would know what unit he has. Thats why ony the cracked asians are released. You can make a simple programmer that uses your printer port on a old pc (forget real name) with some 100 ohm resistors????
Xprog box 5.5.5 Flash + eprom
hello
xprog 5.55
*Atmega64 41
Config.v5.5.5.bin
EEPROM 5.5.5.bin
Flash 5.5.5.binaounzine@yahoo.fr
EEPROM 5.5.5.hex
Flash 5.5.5.hex
These users thanked
motpass please
hi friends
i write flash and eeprom after erase both them but without fusebit
i confirm good write fine reading it after write and comparate data, all is ok
you think xprog will work fine or i must made again using fusebit ?
motpass please
thanks!
