Results 1 to 3 of 3
    Default Mercedes Sprinter need DPF off
    Hi friend! I have Sprinter without DPF (its damage). I need help of remove DPF in ECU
    ECU Soft 1037391213
    mariusica_boy's Avatar
    Quote Originally Posted by vladtimmy View Post
    ECU Soft 1037391213
    Let the tool to make checksum.
    Disconnect connector from temperature sensor and sensor differential pressure.
    Pass in PM.
    TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
    If I helped you please use button Thanks.
  3. The Following User Says Thank You to mariusica_boy For This Useful Post:
    abdomm (15th April, 2016)
    please pass
