Results 1 to 15 of 23
    Jan 2009
    Default hantek 1008c usb oscilloscope
    I just touched probe gnd to gnd of pcb that was testing and usb disconnected. After no more ding/dong when connect to usb and no led on
    I found 3v3 regulator damaged and also mcu STM32F103C6
    Any chance someone to read with jtag mcu?
    Tnx
    rideon's Avatar
    RO
    Well, you found it the hard way...
    For anybody interested here is
    How NOT To Blow Up Your Oscilloscope!
    A failure will not appear till a unit has passed final inspection
  3. The Following 6 Users Say Thank You to rideon For This Useful Post:
    Gavra (14th April, 2016), marty35 (14th April, 2016), Meat-Head (24th November, 2018), phanminhnhat (23rd June, 2016), triak88 (10th September, 2021), zogic (25th June, 2019)
    Jan 2009
    I connect only gnd to gnd... but also my usb hub demaged. Not know if problem was in hub that demaged usb oscilloscope too
    rideon's Avatar
    RO
    Quote Originally Posted by ziko View Post
    Is called ground loop ,and IF everything IS grounded then you got no issues
    Better to be safe than sorry, next time use the scope on a laptop running on battery,is the easiest/cheapest way to stay out of trouble..
  6. The Following 2 Users Say Thank You to rideon For This Useful Post:
    Aug 2015
    Tnx
  8. The Following User Says Thank You to phanminhnhat For This Useful Post:
    rideon (27th June, 2016)
  9. #6
    jodank's Avatar
    Planet Earth
    Hi!
    Are you repaired your scope?
    If yes, any sharing pls?
    Thanks.
  10. #7
    Jan 2009
    I need dump for mcu. Still not found
  11. #8
    rideon's Avatar
    RO
    Can't help with a dump...
    Still, if a ground loop fried your device the mcu should survive...
    on sigrok.org is mentioned Low-dropout voltage regulator: Advanced Monolithic Systems AMS1117-3.3 try checking that and the capacitors around that..
  12. #9
    Aug 2015
    Thumbs up
    This's my hantek S/N
    And dump in attachment.
    Good luck!!!
  13. The Following 8 Users Say Thank You to phanminhnhat For This Useful Post:
    engwaleedfarag (20th April, 2024), hbalazs (4th March, 2022), lounadak (18th December, 2016), rideon (4th September, 2016), seregar1 (2nd March, 2022), SVN1962 (31st March, 2025), ziko (27th November, 2018)
  14. #10
    Dec 2016
    How i can download this dump to my oscilloscope? Which programm i should use for that? My oscilloscope doesn't work, when i connect him to my computer, it connect and then disconnect the connet and then disconnect. I think this problem in microcontroller. I want to renew firmware. Could you help me? I write it from Russia. Please help.
  15. #11
    Jan 2009
    Hi, I put hex to new mcu, now sw recognize hw but measurent is not works on any channel. Reference 1KHz signal is ok (measured with other scope)
    Any tips?
    All 8 channels not works, as I see all chaneel has
    74hc4051d
    TI29AVG 8 pins not know what IC is this
    HC595 cmos 3 pcs
    and MCU
    As I see common part for all 8 channels is MCU only, So not know if data is ok or .... something else
  16. #12
    rideon's Avatar
    RO
    Take a look at this link
    The only difference i see is they have "TI 25 AVG" and yours is "TI 29 AVG"
    As they mentioned, that must be some kind of opamp used in the frontend of all 8 channels
    - Chinese low cost replacement with their own markings-
    Poke a multimeter at that pcb and check if 74hc4051d has power
    Took a look at the pictures on sigrok site .. U427,L403,C401,D406 form a boost converter
    Check the voltage in that area if your board is similar...
    I might be wrong ,in that area is a testpoint TPVEE that might be the power for the frontend
  17. The Following 2 Users Say Thank You to rideon For This Useful Post:
    Meat-Head (24th November, 2018), ziko (24th November, 2018)
  18. #13
    Jan 2009
    L403,C401,D406 are ok, +5v comes to IC smd code LTRA = LT1931.
    By datasheet it convert +5v to negative -5v (by other component I see and sch from datasheet) but there is no -5v on output pin
    Also all 74hc4051d and othewr CMOS ics have 1.5v, what's is not good, 5v expected... and cant find where from get those +5v (not from usb)
    I tried shotrly to bring +5v from usb power to those cmos, patern is goes streight but still not work
    Yes, on PCB exactly like sch from datasheet
    And when follow pcb track that -5v needed for all TI29AVG 8 pins OPAMP
    Thats must be problem, but where to find this LTRA = LT1931?? Maybe inside some HDD
    And also problem power for cmos ics
  19. #14
    rideon's Avatar
    RO
    Using Meat-Head's crystal ball ...
    The opams(TI29AVG) need -5 GND +5 to operate
    To fix the negative rail you need another scope..
    Scope the input of L1B ...
    74hc4051d don't need negative rail ,that part should work on usb power,
    maybe there is some diode gone open circuit or some caps gone short...
    Near the USB plug are 2 diodes D5 must be good if LT1931 got power,you need to check D8
    By the look of the back, i bet that most of the power traces are there...
    Done editing...
    ziko, You realize that after you find what parts are needed,order/pay/fix the damn pcb,
    The time and money aren't worth it....this one is for educational purposes only....
  20. The Following User Says Thank You to rideon For This Useful Post:
    Meat-Head (27th November, 2018)
  21. #15
    Jan 2009
    No any activity on L1B (I use other autoscope, maybe no fast enought for this aplication)... I made my own negative 5v with ne555, put short6 from +5vusb diode to CD.... ICs vcc and work... now must order LT1931 and find VCC problem to CMOs ics
    Thanks for helping
