Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
  1. #16
    Jan 2009
    I found one bad resistor , can you please test and tell me value, Its R15 near USB power diode. and also value on it, but not understand what is exactly... maybe small value used as fuse because comes in serie with VCC to Ics and USB +5v
    I found other 01X on board, its 10 Ohms
  2. The Following User Says Thank You to ziko For This Useful Post:
    rideon (26th November, 2018)
  3. #17
    rideon's Avatar
    RO
    LT1931 switches at 1.2 or 2.2 MHz ,nothing fancy there,no need for a 'proper' scope
    01X is indeed 10 ohms +-1%
    Now allow me to a smartass and complain about your soldering temperature(too high) and total lack of flux...
    That looks like something i would do (or done already)
    A failure will not appear till a unit has passed final inspection
  4. #18
    Jan 2009
    I soldered wires there to test And use flux paste Amtech NC559
    Very thanks for your help, especially for HEX for mcu
  5. The Following User Says Thank You to ziko For This Useful Post:
  6. #19
    Jan 2009
    Received LT1931 yesterday,now scope fully functional. Thanks again to all that helped.
  7. The Following User Says Thank You to ziko For This Useful Post:
    rideon (24th December, 2018)
  8. #20
    Mar 2022
    And my Hantek 1008 broke. On the minus of the case turned out to be a plus. The controller is damaged. On the controller's pinning bus, the resistance is 23 ohms. We need to look for a closure.
  9. #21
    Mar 2022
    I can't download the dump. Help please.
  10. #22
    Jan 2009
    Strange,I didn't find info how I wrote mcu. As I remember I used segger jtag but not know other things
    I guess connector is 1:1 all pins
  11. #23
    Newbie engwaleedfarag's Avatar
    Feb 2019
    No words can express my gratitude , i could repair my scope with your file
    Thank you very much
