Client lost key. I program by effi second key T5 12 but there is start error. On immo there isn't error but in ecu there is p1630 - immobilisser. I post ecu, immo and key data
ecu b58383 - 24c02
immobox hc05x32 0j62d
key data: C1AF392FC718FA99
ecu b58383 - 24c02
transponder data temic 12: 2F C7 18 FA 99 C1 AF 39
virgin ecu:ecu virgin.rar
abdomm (15th April, 2016)
Solution without SD?
Without SD solution...... but not sure for your T5 anymore.....I think u need new one after this file.
your ecu file is 24c04 not 24c02
True ,when it finds VIN I did not check it for length, but according to decoder Sprinter only have 24C02 and must be used SD after. Vito uses only 24c04 in conjuction with HC05 or HC08. And loaded as Sprinter original file is without error. Maybe wait for someone who knows how to check manually . Or try to read your ECU as 24C04 to see is it repeating or it is 24C04.
mellon (16th April, 2016)
ok. I check this file lenght but maybe this is sprinter not vito. I only have rusty ecu witout sticker/label on it and temic immobox.
This is mercedes sprinter.
Then I do not have solution without SD.....
